FS: Quaife LSD
Old May 13, 2012 | 06:19 PM
jnathan68's Avatar
jnathan68
Default Quaife LSD
Used Quaife LSD in housing. Approximately 40,000 miles. Pretty much ready to install in car. 3.5 gear ratio (stock 350z gears from manual trans VLSD)
I have always used Synthetic oil and the differential works great. Only reason I am selling it is because car is going back to stock.
Comes with housing and the 2 solid diff mounts shown. Also comes with NISMO finned diff cover however, the stud in the back of the cover sheared and the rest of the stud will need be removed from cover and new stud purchased (or can use a different cover).
Pending to a local buyer - $800 shipped in the lower 48 (sorry, shipping is expensive since it weighs about 100 lbs).
Old May 14, 2012 | 06:44 AM
jmahad01's Avatar
jmahad01
I probably would of been interested if it wasn't for the sheared stud on the nismo diff cover. Make sure your get that oil off your brick floor...
Old May 14, 2012 | 07:26 AM
dab69's Avatar
dab69
what gear ratio?
Old May 14, 2012 | 07:33 AM
jnathan68's Avatar
jnathan68
Originally Posted by dab69
what gear ratio?
Stock 350z Manual Trans VLSD ratio. 3.5 I believe, someone can correct me if I am wrong.
Old May 14, 2012 | 08:03 AM
Naut's Avatar
Naut
PM'd.
Old May 14, 2012 | 06:27 PM
zeehee's Avatar
zeehee
$5 bolt extractor bit and it's back to normal.
Old May 15, 2012 | 08:58 AM
jmahad01's Avatar
jmahad01
^ I have had bad experiences lol. The cover may be aluminum though which would be pretty easy I guess. If he does not sell it soon I will probably pick it up.
Old May 15, 2012 | 03:31 PM
jnathan68's Avatar
jnathan68
I had a bolt extactor and was able to remove the sheared stud today. New stud is around $8.00 shipped (one on its way). However, diff is pending to a local.
Old May 15, 2012 | 07:45 PM
xjuddx's Avatar
xjuddx
let me know if your local buyer falls through. I might be interested.
Old May 15, 2012 | 07:48 PM
SE5spd's Avatar
SE5spd
What diff are you going with next
Old May 15, 2012 | 07:52 PM
0jiggy0's Avatar
0jiggy0
Thats an excellent price.
Glenn350zHR
Drivetrain
Nov 30, 2015 08:21 AM
bcoffee20
Nov 19, 2015 06:39 PM
Paul.
Oct 16, 2015 07:34 PM
RiujinZero
Sep 25, 2015 01:19 PM
3vilbunny
Sep 13, 2015 12:31 PM
