Full Fluid change kit from MA Motorsports
MA Motorsports is here to help make your life easier, below is a full fluid change kit with the intervals that we recommend. I will split them up if you like, just shoot me a PM. I can also get many other brands if you have a preference!
This kit is every fluid you would need to change at one time:
For the Oil change, we use Motul 300v because it is an Ester based oil like Nissan recommends for the HR motor due to the VVEL system, with non-ester oils there can be pre-mature wear on the system. I can get other oils if that is what you are interested in.
Oil Change -- We recommend 5k for cars that get driven hard, or see track days. Even more often depending on how much it is tracked and how hot it gets.
Motul 300v x 6 liters
K&N Filter
Magnetic Drain Plug
Transmission Fluid Change Kit – We recommend 15k or once a year for cars that get driven hard, or see track days. Even more often depending on how much it is tracked
RedLine MT85 x 4qts
Diff Fluid Change Kit (if you have an LSD, let me know. Some use specific fluids such as OS Giken, and we can switch that up) -- We recommend 15k or once a year for cars that get driven hard, or see track days. Even more often depending on how much it is tracked
RedLine 75w90 x 2qts
Power Steering Kit -- We recommend 15k or once a year for cars that get driven hard, or see track days. Even more often depending on how much it is tracked
Redline D6 ATF x 2qts
I do not include coolant, or water wetter due to people having track regulations to meet or not meet. I can add either if you like!
FULL Kit $264 with free shipping to the lower 48 states
Kit with NO Oil Change $139.00 with free shipping to the lower 48 states
PM me for payment options!
K&N Filter
Magnetic Drain Plug
RedLine MT85 x 4qts
