somebody help me~
Old Dec 15, 2007 | 07:06 PM
optimumarc's Avatar
optimumarc
I have a Nismo CAI and had the same issue. The Nissan dealer mentioned to me that oil should not be applied since it may cause the mass airflow sensor to malfunction. So I just wash it, let it dry and install. I am assuming that the filter has some type of material which will cause the dirt particles to adhere to it without the use oil.
Old Dec 16, 2007 | 03:12 AM
bender's Avatar
bender
I've never not oiled an air filter. I've always been under the impression that it's the oil that traps most of the particles and not the filter itself.
Old Dec 16, 2007 | 04:15 AM
Eazzy's Avatar
Eazzy
I have said a dozen times in here.....If you have a reusable filter that requires oil, If done correctly (and that is very simple) has no adverse effect on sensors. Period.
I have also said---If you dont oil the filter, you might as well throw it in the street. An unoiled filter IS NOT a FILTER.
Old Dec 16, 2007 | 04:34 AM
bender's Avatar
bender
Originally Posted by AVmagneticZ
do you have to oil every filter? i baught the fujita short ram kit and it said nothing about applying oil to the filter? should i do it anyways
Some filters come pre oiled. I believe Fujita does this with their filters.
Old Dec 16, 2007 | 04:50 AM
Eazzy's Avatar
Eazzy
All reuseables do---after that it is your responsibility to clean and reoil yourself.
If they didnt, people would be installing unfiltering filters and sueing the manufacturer
