spark plugs
Old Dec 18, 2008 | 12:57 PM
nick123's Avatar
nick123
Default spark plugs
Called the dealer and they said i need ngk platinum plugs at 25 each....WTF
I walked into parts source and got the same patinum plugs for my 03 350z for 12.00
Are teh iridium any better
They should be the same.??????
Old Dec 18, 2008 | 01:48 PM
rchaud411's Avatar
rchaud411
in actual fact, to get the best spark possible you would want to go with copper. platinum plugs just last longer but have less of a spark and even worse for iridium, they just last even longer then platnum but have even less spark. i learned this from neetronics (paul neethling) when i had my wrx tuned. He highly supports copper plugs as they have the best spark and less blow out. The downside to the coppers is that they need to be properly gapped and dont last very long, especially with FI. with coppers you would have to change them at minimum once a year. correct me if im wrong guys. either way you will be fine. just maybe have to be replaced before the recomended 50km or what ever it is.
Old Dec 18, 2008 | 01:49 PM
0jiggy0's Avatar
0jiggy0
Dealerships always have heavy markup, thats why we call them stealerships silly.
Old Dec 18, 2008 | 02:42 PM
edvy's Avatar
edvy
i remember agincourt nissan only charging 17 each
i m using NGK iridium currently
Old Dec 18, 2008 | 03:24 PM
nick123's Avatar
nick123
My car is stock pretty much...so i just got the ngk platinum...MEH, seeems like a good price.....I wish they had the double platinum...But i have never heard of that
Old Dec 18, 2008 | 04:36 PM
Black Z Eddie's Avatar
Black Z Eddie
You decide:
http://tinyurl.com/48dv8v
Old Dec 18, 2008 | 06:12 PM
aRYip's Avatar
aRYip
copper plugs should be the better plugs for performance...
but copper plugs last not very long...
iridium just last longer...
Old Dec 18, 2008 | 07:03 PM
goneinsixtyseconds's Avatar
goneinsixtyseconds
i used the g-power platinum 6 heat-range for about 15K and they were showing minor signs of arcing (which apparently is a bad thing), so i switched them out for the iridium ix in the 7 heat-range and i did notice an improvement on idle. power loss from heatsoak didn't feel as bad either.
burglapfd
Dec 6, 2020 01:04 PM
350z82
Oct 1, 2015 06:25 PM
35reilly
Sep 28, 2015 07:42 AM
