Car seems squidgy/hopping while cornering
Old Apr 20, 2010 | 07:30 AM
maroli's Avatar
maroli
Default Car seems squidgy/hopping while cornering
Does anyone else have this problem? Is it the bushings? When I corner (I have tein flexes and 255/275) hard, there is an odd feeling like there is some flex between the chassis and the wheels, almost like the wheels are moving slightly laterally independently of the chassis in the rear. Can this be cured with stiffer bushings?
Old Apr 20, 2010 | 07:32 AM
Reality350's Avatar
Reality350
Tire pressure low?
Old Apr 20, 2010 | 10:20 AM
maroli's Avatar
maroli
Originally Posted by Reality350
Tire pressure low?
hmm, good theory. I'll check, but I just mounted these last month so I don't think that's the case.
Old Apr 20, 2010 | 10:44 AM
brady's Avatar
brady
What tires are you running?
Old Apr 20, 2010 | 10:47 AM
maroli's Avatar
maroli
sumitomo HTR-Z III 255/40/18 275/40/18
Old Apr 20, 2010 | 11:52 AM
kasimmmmm's Avatar
kasimmmmm
YES! I experienced the same damn thing and it freaked the **** out of me the first time around.
It did this for me when I was getting onto the 407, making a slight right the first time. Ever since, I've noticed it does that at higher speeds while turning.
is it the same for you? is yours an 03?
EDIT: I'm not sure if we are both experiencing the same thing, but it feels like the front corner of the car twitches or hops?
I'm running Goodyear Eagle F1 GS-D3, and when it first did it, I was running Bridgestone RE-11s. It did it with both setups. Its definately not the tires.
Old Apr 20, 2010 | 07:30 PM
JEFFOS69's Avatar
JEFFOS69
Could be the suspension is not set to the right stiffness and you could be understeering (plowing)
Also check your alignment - it can make a huge difference if it is off. Another thing could be check the sway bars and the bushings and make sure they are on tight.
Old Apr 20, 2010 | 10:14 PM
maroli's Avatar
maroli
I get the feeling when its just starting to understeer but its more at the rear, it almost feels like the sidewalls are flexing, but I know its not the tires. I don't have aftermarket sways, but I'll try stiffening up the edfc and checking the bushings
Old Apr 24, 2010 | 04:30 AM
XuperXero's Avatar
XuperXero
Some runflats are known to cause this issue too... but I dont think sumitomo are runflats.
etkms
Jun 19, 2022 06:30 PM
reno56
Interior
17
Nov 20, 2015 05:21 PM
ddegrande21
Sep 6, 2015 11:15 AM
