Window Problem, Help??
Old Sep 21, 2010 | 04:40 PM
BashaZ's Avatar
BashaZ
Default Window Problem, Help??
So a couple days ago my driver side window started acting up. When I would close it, it would go all the way up and then come back down to half.
The only way I could get it to close fully was to hold the button all the way up to the top.
Today on my way home, My window decided it won't go down at all! Only the Driver side the Passenger side goes down no problems.
I still here the "click" noise when I push the button, or even when I push the button on the door release.
What would the problem most likely be? the Motor?? Let me know please!
Old Sep 21, 2010 | 08:41 PM
350zlee's Avatar
350zlee
Is your car under warrenty? if u do, bring it back to dealer, they will reset the window motor for u. This is what I did. If not, then search on the tech forum, some post teach you how to reset the window. goodluck.....
Old Sep 21, 2010 | 09:18 PM
BashaZ's Avatar
BashaZ
Thanks Man, Ill try that tomorrow!
Old Sep 22, 2010 | 08:30 AM
GT-Rob's Avatar
GT-Rob
If they don't cover it, its very easy to do (assuming its just a reset). Remove door panel, press reset button, done.
Your motor will die though, its just a matter of time
Old Sep 22, 2010 | 09:00 AM
BashaZ's Avatar
BashaZ
So should I just change the Motor while I have everything opened up?
Old Sep 22, 2010 | 09:25 AM
350zlee's Avatar
350zlee
For me, i will try to reset the motor 1st..........if everything works fine. Then u don't need to spend money on the new motor. If it doesn't work, then u need to change it.
Old Sep 22, 2010 | 10:16 AM
BashaZ's Avatar
BashaZ
Wow, so I went to reset my window, and before I did, I just pushed the window button to see if it would work lol. And the window came down, it's working perfectly normal now.....
So weird
Old Sep 22, 2010 | 01:59 PM
shinobi_350z's Avatar
shinobi_350z
Your motor is dying. DO NOT BUY THE MOTOR FROM THE DEALER when you replace it.
they charge 500/window motor. You can by aftermarket replacement motors for 150 or so.
Old Sep 22, 2010 | 02:01 PM
cdoxp800's Avatar
cdoxp800
Had the same issue. Did the NTB04-089 Window Regulator Motor Reset Procedure. Zero issues now.
Old Sep 23, 2010 | 06:28 AM
GT-Rob's Avatar
GT-Rob
Yes the window motors are made of garbage or something and stop working eventually. Every Z owner needs to know, if you are still in warranty, get them both replaced before it expires! It will at least buy you a few years.
NAPA carries after market replacements for much cheaper, but its still not cheap, and I hear they still die after a couple of years.
Old Sep 23, 2010 | 07:50 AM
BashaZ's Avatar
BashaZ
yeah I called them earlier, it's $193.44
I use hot spot for a lot of my car parts and they were a little cheaper at $182
Old Sep 23, 2010 | 10:44 AM
stanleylee's Avatar
stanleylee
re-build ur own motor,
oem motor are always better then those aftermarket "rebuild" one
my diver side has rebuilded and it work like a champ now
Old Sep 23, 2010 | 02:37 PM
BashaZ's Avatar
BashaZ
Well as of now, I opened it up and reset it , let's see how long that lasts, it seems to be working ok.
I actually got the guy at NAPA to give me the Motor for $165 if I ever end up needing it. If it last me more then 3 years I'll be happy because I won't likely have the car for that long.
Old Sep 23, 2010 | 05:07 PM
Risky_Business's Avatar
Risky_Business
Quadrant 987c
Default Fix...
your window and come to the meet on Saturday.
- RB.
Old Sep 24, 2010 | 06:27 AM
BashaZ's Avatar
BashaZ
- RB.
I would come, but you are having it in Markham AT 10AM!! that's like a half an hour drive for me man. I don't like getting up at 9AM on my days off. I might come up though, depends how late I stay out tonight after the Leafs game.
Old Sep 27, 2010 | 04:05 PM
cogracon's Avatar
cogracon
Unhappy Was waiting for this...
I researched the Z before I picked up a 2007 Roadster a couple of months ago, and noted the window problems. Well today I found water in the car after sitting outside in the rain all day. After inspecting at home, I realized the driver's side window stayed open just a couple of millimeters (<1/4 inch), enough for a bead of water to seep through.
I'm guessing I just need the window limits reset, but I'm not handy enough to do it myself. We'll see how much this costs me when I get my oil changed. Window works fine otherwise.
Old Sep 27, 2010 | 04:09 PM
surfcity40's Avatar
surfcity40
Thanks for remembering the issue.
Old Sep 27, 2010 | 04:12 PM
Risky_Business
Quadrant 987c
Default LOL....
true. Did you come? I forget...
- RB.
Old Sep 27, 2010 | 07:23 PM
BashaZ's Avatar
BashaZ
- RB.
No man I didn't end up coming up there, I set the alarm and totally ignored it....believe me I wanted to, but I was passed the hell out
I'll definitely catch the next one though
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
