Longshot. LF SG Long tube headers.
Old Jan 15, 2013 | 08:21 AM
2TH PWR's Avatar
2TH PWR
Default Longshot. LF SG Long tube headers.
I need these.
I have Momentum headers. ART PIPES. And OEM cats as well as cash to trade.
If you were looking to unload or part out please let me know.
edit if you check my build thread you will see the momentum headers and art pipes are basically new.
Reason for switch is dedicated track car. will never need to pass e test again. And swapping in built NA motor.
Old Jan 15, 2013 | 08:28 AM
cyc5181's Avatar
cyc5181
Or you can get a set of PPE LTs, think someone is interested to sell.
Old Jan 15, 2013 | 08:33 AM
2TH PWR's Avatar
2TH PWR
I don't know if they PPE's will suit my needs but I will check. I heard the Fast Intentions ones were close to SG's but I can't find any available.
Old Jan 15, 2013 | 09:15 PM
Pholicious's Avatar
Pholicious
If you sell your art pipes lmk
Old Jan 16, 2013 | 04:17 AM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
I WANT PPEs msg me
Old Jan 19, 2013 | 01:53 PM
Wu-Watt's Avatar
Wu-Watt
Would Sasha make a set for you? I bet if you got a group buy of 5 or so he'd do it. Bet he still has the jigs.
Twist his arm.
Old Jan 19, 2013 | 02:20 PM
2004Black350z
Exhaust Whore
I'm down
Old Jan 19, 2013 | 02:54 PM
KingBaby's Avatar
KingBaby
Hardest Setting
If he does then I'll be pissed!
Several of us tried in pm's and several of us were down for the groupbuy!
Folks couldn't cough up money for PPEs so don't see 2k headers being brought
Old Jan 19, 2013 | 03:29 PM
0jiggy0's Avatar
0jiggy0
Pipe dream
Old Jan 19, 2013 | 05:33 PM
2TH PWR's Avatar
2TH PWR
Sasha told me I could get new ones yes through centerline motorsports as long as I found one other guy. Only problem is I'm very strict with a budget. They are 2200 bucks. Which after buying a lot of new things this year I am worried will be too much. Figured I would try the trade route first. I guess I could sell my art pipes momentum headers and current motor? But right now I'm still on the fence
Old Jan 19, 2013 | 05:39 PM
2TH PWR's Avatar
2TH PWR
I guess if you are really committed to 2200 for a new set pm me. Mows the easiest time for me to instal them
Old Jan 19, 2013 | 06:42 PM
Wu-Watt's Avatar
Wu-Watt
Then you need Carbotron!
Old Jan 19, 2013 | 08:31 PM
bingbing's Avatar
bingbing
Sasha is bringing back his tuning business too: http://www.onpointdyno.com/
I'm going to Centerline this week to pick up a manifold and commission some other stuff.
My recommendation would be to F the budget and just buy them... Rene will treat you right
Old Jan 20, 2013 | 03:42 AM
2004Black350z
Exhaust Whore
wow 2200 huh...... I was thinking 1500...
turns around and runs
Old Jan 20, 2013 | 04:45 AM
mw9's Avatar
mw9
why wont PPE suit your needs? At $2200, I think he just doesn't really want to make or sell them, I just cant believe you will get twice the performance with SG's than PPE.
Old Jan 20, 2013 | 05:17 AM
XChacalX's Avatar
XChacalX
the PPE are too small for the C10/C9 JWT Cams.
I emailed PPE earlier this week about the possibility of making another version of those step long tube headers because Im also looking for something similar to what Mike is looking for.
but having to use bigger tube , they would need to make another *jig*
and the need to have the car in for the first set...
soo right now his Momentum header (bigger primary) with test pipe is comparable to the PPE headers (smaller primary) then their secondary has the same diameter than the Momentum.
as far as the Carbotron upper plenum, there is a reason why he didnt kept it on the engine.(not strong enough)
then Sasha modified an OEM upper plenum and yeilded similar result.
Old Jan 20, 2013 | 06:29 AM
andre12031948's Avatar
andre12031948
Over 3 years ago I started to mod my car (08 350z). I noticed that alot of people jumped into changing the intakes with shiny new ones. I looked at my stock ones & saw that the filter was inside of a box & got its air from the outside. I even realized that fresh air might be forced up from the underneath the car. The aftermarket ones drew warm air from under the hood with very little ram air affect. I scratched my head & kept my stock ones.
I'm always looking for a little more H.P, so these new headers caught my eye.
Unless I missed something, so far I've seen no information/data that shows an increase in H.P. of an H.R. engine on a dyno or at the track.
Is it fair to ask, why should I do this????
Old Jan 20, 2013 | 07:41 AM
Wu-Watt's Avatar
Wu-Watt
I didnt know that! Looks really cool tho. I actually sold Sasha my rev up plenum since i have a kinetix, years ago. I wonder......
Old Jan 20, 2013 | 08:41 AM
XChacalX's Avatar
XChacalX
hehe, I cant remember which upper plenum it was, so yeah there is gain to be gained at the rear intake tubing . it could even be optimised from what Sasha did.
I think Carbotron said on ziptied that if someone would have the $$ to have an upgraded carbon plenum (stronger) he could make one.
there is a video on youtube when they tested the carbon plenum and under vacuum it was bending crazy toward the inside !
Old Jan 20, 2013 | 10:20 AM
KingBaby's Avatar
KingBaby
Hardest Setting
See that I didnt know you had and HR? I'm pretty sure with your beating around the bush no one does!
sales@czp
Sep 23, 2019 03:30 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
_bit
Oct 2, 2015 07:49 AM
Depravity
Oct 1, 2015 04:49 PM
