FS: wheel hubs / bearings / subframe
on
3 G35 / 350z wheel hub & bearings... no studs, i had ARP studs and pressed them into my new hubs... turns out it was an alignment issue not a hub / bearing issue... other than the one not pictured here. i'm not sure which are fronts and which are rears at this point
$100 for all 3.
I also have this 350z subframe that i was going to use like my s13 one to make multi-link for but i dont really have the time to do that anymore... nor the interest.
$50 for it and i expect to have access to it if you don't install it maybe someone else wants to work with me on the multi-link just so that i can get this out of my garage?
I also have the following items BNIB:
350z Top Speed test pipes - $145
370z Top Speed test pipes - $185
350z Y-pipe - $185
$100 for all 3.
350z Y-pipe - $185
