High Performance Clutch
Currently looking for a high performance clutch capable of 600ft-lbs of torque at the wheels. Opinions, comments and suggestions??
After some research, I am leaning towards a clutch master stage 6.
Tilton Semi-Street!!!!!!!!
http://www.performancenissanparts.co...roducts_id=201
A little extreme, but well worth it!!!!!
BTW, I just found an informative thread in the FI area on clutches.
Here's a quote from the member Egbert..
"I burned up the Tilton clutch and flywheel in a relatively short time, primarily because I was trying to drive it smoothly on the street, which requires a 3-footed dance on the pedals, and a lot of clutch feathering. Well it turns out that that is just clutch abuse.
The dealer was nice enough to give me a new clutch disk and pressure plate free or under warranty. All I had to pay for was a new flywheel. So the Tilton set-up is nearly new (less than 1000 pampered miles). It is a hairy chested mod for the serious few. Don't ask for my Tilton set-up unless you are sure you want high performance at the cost of reduced street driveability."
I don't know if that clutch is streetable.
I also just found out that I need to replace my clutch, 03 with 32000 miles. Dealer told me that they are seeing clutch replacement between 30000 and 35000 miles. I am thinking about going with the Nismo clutch and flywheel, parts and installation $2000.00.
$2000? I think Performance Nissan charges a hair over $1200 for the Nismo clutch/flywheel and install.
