Strut Bar recommendations ???
Old Dec 19, 2004 | 09:33 AM
JCat's Avatar
JCat
Default Strut Bar recommendations ???
What strut bar would you recommend to accommodate a Crawford Plenum?
Show us a picture if you can.
Old Dec 19, 2004 | 11:07 AM
coachk's Avatar
coachk
JIC makes a real nice carbon fiber one that fits, or just go with the Crawford one its less expensive. but you do have to modify your engine cover with the Crawford.
Old Dec 19, 2004 | 11:16 AM
ssc's Avatar
ssc
whoa, i didnt know the cf jic one fit...i thought u could only use the crawford one or the stillen one.
so only the jic cf one fits? how about the aluminun jic one?
Old Dec 20, 2004 | 08:01 AM
Tony@Performance's Avatar
Tony@Performance
Vendor - Former Vendor
No, the JIC won't fit, at least not from what I've seen. The JIC one is flatter than stock, but wider, and gets in the way still. I'm not sure if you can space the strut bar up a little and clear?????
(with washers or what not)
Old Dec 20, 2004 | 09:47 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
only one that fits AFAIK is Crawford and I suspect Stillen might as well
Old Dec 20, 2004 | 02:17 PM
teh215's Avatar
teh215
None of the current strut bars help us poor Vortech/Crawford folks...
Old Dec 20, 2004 | 03:01 PM
leemik's Avatar
leemik
That won't work.. My JIC bar rubs up slightly againt the hood already (there are marks on the bar)..
--mike
Old Dec 21, 2004 | 11:32 AM
TheBigShow's Avatar
TheBigShow
i've heard something about the craw hittin the hood, too. i think it was just a one bar thing though. i'll probly still go with one of theirs.
Old Dec 22, 2004 | 10:59 AM
spf4000's Avatar
spf4000
The design of the Crawford strut bar isn't really good because of the brackets they use to move the strut mounts forward. This design will flex at the mounts and would not add very much torsional rigidity. I suppose it's better than not having anything, but just don't expect it do much.
Old Dec 22, 2004 | 11:20 AM
TheBigShow's Avatar
TheBigShow
so get a stillen?
Old Dec 22, 2004 | 01:39 PM
randyshemin@comcast.'s Avatar
The bar was the only part of the car unscathed after this....
He was able to put it on the new car that replaced this one!
Old Dec 22, 2004 | 01:41 PM
PhoenixINX's Avatar
PhoenixINX
FYI, our bar vs the stock is actually stiffer.
With our design the "mounts" will not flex. Had a thinner guage of steel been used, it may have been more likely. However the design is using thicker parts than even stock!
Did you notice the stock bar already has an expansive curve in it? Yikes! Talk about a structional flaw!
This is high-school physics, which is stronger... a straight bar or a bent?
If anyone is in the area, feel free to come down to the shop and take a look yourself.
Old Dec 22, 2004 | 01:51 PM
teh215's Avatar
teh215
You know this argument is going to go on forever until you put both in something that can measure the "crush resistance" of both and prove it. I tend to believe that yours is stronger though...
Old Dec 22, 2004 | 02:42 PM
PhoenixINX's Avatar
PhoenixINX
We did!!!
Our bar held past 10k psi, however the OEM started bending at far less.
Old Dec 22, 2004 | 08:02 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
Our race team tested the OEM STB / JIC / GREDDY / GT-SPEC...
They still use the OEM...
Havent tested any of the plenum accomidating STB's yet...
Old Dec 22, 2004 | 08:10 PM
PhoenixINX's Avatar
PhoenixINX
I know, it sucks!!!
They won't let ANY of the Grand Am cars change out their plenums!!!! WTF?!?!
Old Dec 23, 2004 | 07:31 AM
TheBigShow's Avatar
TheBigShow
anybody's craw bar hittin their hood? thanks.
Old Dec 23, 2004 | 08:44 AM
DLin05's Avatar
DLin05
i need a strut bar in the worst way....Crawford one wont fit over the HKS and stock wont fit over the Crawford plenum. Suggestions anyone?
Old Dec 23, 2004 | 09:42 AM
leemik's Avatar
leemik
Get a new hood with more room? then put some washers under the strut bar to raise it slightly?
--mike
Old Dec 23, 2004 | 01:15 PM
LOU's Avatar
LOU
BigShow-
I had the Crawford bar before I installed the Vortech. It touched the hood and made marks. I have looked at other people's hoods and they all had marks from the Crawford bar as well.
