UR Pulley Set....power gains? worth getting?
Old Jan 12, 2005 | 12:37 PM
Losing Grip II's Avatar
Losing Grip II
Default UR Pulley Set....power gains? worth getting?
i am interested in adding more power to my Z. will the UR pulley set (alt, ect.) add decent power? what are the average power gains with the UR set? is there a better set?
john
Old Jan 12, 2005 | 12:39 PM
axxizzer's Avatar
axxizzer
thre are power gains because of light weight and under-driving
there is no way that you cant make power with this mod. However it might mess with the harmonic balance of the Z.
It should add around 5hp and UR is the only company I have seen that makes a pulley for the Z
Old Jan 12, 2005 | 02:37 PM
Losing Grip II
can i replace all but the crank pulley, or is that where most of the power lies?
john
Old Jan 12, 2005 | 02:44 PM
orhanz33's Avatar
orhanz33
the crank pulley is the one that makes the difference
p.s. harmonic balance on the z is not affected
Old Jan 12, 2005 | 03:09 PM
vitaminZ's Avatar
vitaminZ
this past weekend at Z1motorsports, Baumer (g35-6speed) dyno'd without the UR pulleys then dyno'd with the pulleys installed. he gained @5hp to the wheels. this was done on the same dyno several hours apart.
Old Jan 12, 2005 | 03:42 PM
TELCO119's Avatar
TELCO119
If you decide to do it, make sure to get all 3 pulleys. I did all three, and I noticed a huge difference right away. You don't get the full effect if you skimp out and just get the crank pulley.
Old Jan 12, 2005 | 06:54 PM
Baumer's Avatar
Baumer
Like vitaminZ said.. I got the full set installed at a dyno day last weekend. I gained 5 rwhp on the dyno and the car revs quicker now. 350zforums.org has them with belts for $320 shipped and the install on mine was $130 - well worth the money!!
Old Jan 12, 2005 | 07:00 PM
Losing Grip II
thanks everyone for the replies. i guess/ assume now that what i have been told is tru about the balance with the engine and changing the crank pulley.
having said that i have decided that this is going to be my next mod along with Crawford's high flow cats and some Toyos so i can get my Gt-7s mounted.
thanks again everyone,
john
p.s. what colors are available?
where the best on-line retailer?
Old Jan 12, 2005 | 07:53 PM
TwoNosBottles's Avatar
TwoNosBottles
Ive read that if you plan on adding extra audio components to your z than you wouldnt want to put all the pulleys on, i think it was written on stillens mag or some place and it kinda made me regret getting a system.
Old Jan 13, 2005 | 09:08 AM
350_Z's Avatar
350_Z
All HP gains are from the crank pulley. Do a search this has been discussed many times. Also if you have other bolt-ons, the pulley tends to lean the A/F out a lot when added to a lot of other bolt on mods. Most have had to get an ECU flash to correct this.
Old Jan 13, 2005 | 11:13 AM
jjellyneck's Avatar
jjellyneck
Huh? I don't get it. Why does the pulley contribute to a lean condition?
Old Jan 13, 2005 | 11:21 AM
sentry65's Avatar
sentry65
the burninator
yeah I must have missed that when reading all the other threads. Oh well
Old Jan 13, 2005 | 11:24 AM
2003z's Avatar
2003z
not according to UR:
http://www.unorthodoxracing.com/faq_pulleys.html
3) "How do Unorthodox Racing pulleys give me more power?"
Weight loss is the most critical factor in making, or more accurately, relesing Horsepower! Each pound of weight taken off the engines rotating assembly is worth approximately 2.7HP and the figure increases dramatically with forced induction, nitrous, VTEC and increased RPM's. [B]Only 15-20% of the gains seen from our pulleys comes from the underdriving.[B] The diameter of each of our crank pulleys is reduced up to 20%. We tailor the exact amount of underdrive to each vehicle based on factory specified accessory performance. We fully maintain all accessory output minimums like air conditioning efficiency, power steering feel, and voltage (minimum allowable voltage 12v) even at idle with everything electrical on in the car. There are no adverse effects from using any of our pulley versions. Bolt them on and forget about them, then just follow your vehicles normal maintenance schedule.
Old Jan 13, 2005 | 02:00 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
the pulley has zero effect on the AFR of your car. The majority of the hp gains are derived from the crank pulley, as your accessory pullies are already quite light
IMHO, its one of the best bang for the bucks mods out there for this car as its inexpensive (relatively) to not only buy, but install as well - which is why it was the first mod I did to my Z (as well as many of my other cars in the past!)
They come in black, blue, red and silver - you can check them out here:
http://z1auto.com/prodmore.asp?model...ine&prodid=718
Old Jan 15, 2005 | 05:00 PM
the7ferret's Avatar
the7ferret
Are the UR Pully underdriven a little? Or are they stock diameter becuase I cant tell from the website?
I was thinking of getting some but I need my alternator to be at peak efficency cause I going to get super mondo stereo.
Old Jan 15, 2005 | 05:43 PM
G3po's Avatar
G3po
Default pullies
The UR crank pulley "does" underdrive the accessories.
If you are adding a very high power stereo you prolly should pass.
The water pump and alternator pulleys are really only for show and produce no measureable gains, regradless of UR's marketing bull.
Old Jan 15, 2005 | 06:11 PM
ssc's Avatar
ssc
so, the final conclusion is that the UR crank pulley does absolutley no harm to the engine and its components?
Old Jan 15, 2005 | 07:04 PM
Z1 Performance
Former Sponsor
yes
FWIW we have customers with some pretty serious stereo mods running the crank pulley without incident. If a truly modo stereo is planned, an aux battery might be a wise choice
Old Jan 15, 2005 | 08:09 PM
Losing Grip II
your all soooo smart......
john
Old Jan 18, 2005 | 09:18 AM
350_Z's Avatar
350_Z
model=350z&cat=engine&prodid=718[/url]
https://my350z.com/forum/showthread....ghlight=Pulley
For all of you that questioned my statement. I've seen a number of posts with this same result. Search before you discount someone next time...
