My VQS1DE is completed...
Old Jan 28, 2005 | 09:35 PM
axxizzer's Avatar
axxizzer
I have 2 simple words for you my friend:
plenum
Old Jan 28, 2005 | 09:50 PM
Z350Lover's Avatar
Z350Lover
axxizzer:
I will be going for that mod soon I would say.... probably the new spacer will do a great job to feed some more air for those high angle cams...
cheers,
richie
Old Jan 28, 2005 | 09:55 PM
Z350Lover's Avatar
Z350Lover
Originally posted by mchapman
Hi Richie,
Nice work mate, those are great numbers!
It making gains from around 2600rpm! Which is great considering the cams, looks like the VTC pulleys did what we thought they would
Murray,
yeah.... I can feel the gain from above 2500rpm... not too bad I would say.... and the VTCs are really needed if you want to go for the wild cams.... otherwise you will not be possible to use all of those higher lift/angle advantage I believe... and also comes with the software to control VTCs, there ain't much options out there really... so whoever can change the OEM ECU or come up with a good and cheap after market ECU to go with the VTC + cams will be the money maker...
cheers,
richie
Old Jan 29, 2005 | 06:16 AM
ALong's Avatar
ALong
Richie,
thanks for the offer, I may have to take you up on it in the future if we move the car to another race class. I think you need to get a Hollinger gearbox for your Z, should make it a bit faster under acceleration....... Are you a V8 Supercar fan?
Thawk408,
I know there are more parts changes to the 35th Anv motor than what I listed, my point is, that according to Nissan Competition the extra 13hp is coming almost entirely from the software upgrade, since the motor is now reving to 7000rpm, a lot of the other parts (new rod bolts, valve springs etc) are there to keep the motor reliable for the next 150k miles. This information was given to me by Nissan Comp in response to my inquiry about purchasing some of these parts to put in the engine of my racecar, their response was it was a waste of money if I already had engine software.
Old Jan 29, 2005 | 07:14 AM
Brandon@Forged's Avatar
Brandon@Forged
Forged Internals.com
Originally posted by FairladyZ
they guys at performance nissan drove one around and said it was the same. Do you mean the track model?
They got an auto 35th anniversary edition, which is 287hp.
Old Jan 29, 2005 | 07:19 AM
FairladyZ's Avatar
FairladyZ
Originally posted by thawk408
I am suppose to receive mine at the end of next week. After I break it in I will put it on the dyno.
sweet
Old Jan 29, 2005 | 11:41 AM
thawk408's Avatar
thawk408
Originally posted by ALong
Thawk408,
I am sure that the revised shape on the piston head, new camshaft profile, VTC on both sides, and modified intake with shorter and wider runners are helping that retuned ECU to get more power. I really doubt that it is all coming from the ECU seeing that all those parts should change the power output of the motor.
Old Jan 30, 2005 | 03:29 AM
Z350Lover's Avatar
Z350Lover
thawk408:
It will surely be cool to see how the 05 revised engine turn out when you got the car.... let us know when you have it dynoed!
cheers,
richie
Old Jan 30, 2005 | 07:18 AM
Landbarger's Avatar
Landbarger
"looks like the VTC pulleys did what we thought they would" Sorry, could some one give me the details on what we thought they would do, sorry for the question, just not sure about what they do better, thanks.
Old Jan 30, 2005 | 01:03 PM
Z350Lover's Avatar
Z350Lover
Landbarger:
Here is the link to the old thread and you might find it helpful!
https://my350z.com/forum/showthread....&highlight=vtc
cheers,
richie
Old Jan 30, 2005 | 02:08 PM
Landbarger's Avatar
Landbarger
thanks
Old Apr 29, 2005 | 06:03 AM
mchapman's Avatar
mchapman
Richie,
What is the lift of these cams?
Thanks
Old Apr 29, 2005 | 12:06 PM
Jun's Avatar
Jun
how much did you end up spending to upgrade with the S1 parts?
Old Apr 29, 2005 | 02:05 PM
UnderPressure's Avatar
UnderPressure
Originally Posted by mojo powered
hey mate! I think those gains are very very respectable, especially if we consider this is a DYNO DYNAMICS dyno. We're not talking about Dynojet here.
I am not an expert to say how conservative the DD dyno is compared to Dynojet but I do know it is quite a bit more conservative. I'd be very very happy if my car put 260 to the wheels on a DD dyno. It all depends to what the calibration is on these dynos of course but people say that these DD dynos are more "realistic" than others. But then, dynojet seems to be the industry standard so that's another long talk.
Well I have a little bit of insight into the answer. Generally speaking dynojets are 13% higher in their numbers than us. Superflow and mustang are ~5-8% higher. Roto-pak is closest to our numbers ~2-3%. Everyone has their reasons for using the correction factors they select.
The numbers are just that, numbers. The thing to look @ are the delta between where you stared and finished.
Back to the thread topic, thanks for the information and the documentation. Decent gains w/ keeping the streetability.
Old Apr 29, 2005 | 04:15 PM
GY-Z's Avatar
GY-Z
Originally Posted by mchapman
Richie,
Thanks
nismo spec 1cam have 276 degrees duration, and .433 " lift. The exhaust cam is 256 degrees duration with .413" of lift.
pretty aggressive cam IMO
350zlover
this setup is nice, be sure to wait for 350evo's plenum.
it'll be really insteresting to see how this setup react with a good NA plenum.
PS lucky you with the Motec.
Old Apr 29, 2005 | 04:55 PM
Z350Lover's Avatar
Z350Lover
Richie,
Thanks
The info of those cams according to nismo are:
INT: 276 degrees with 10.7mm lift
EXT: 256 degrees with 10.1mm lift
and the standard figures are:
INT: 238 degrees with 9.5mm lift
EXT: 240 degrees with 9.5mm lift
cheers,
richie
Old Apr 29, 2005 | 04:57 PM
Z350Lover's Avatar
Z350Lover
Jun:
I ended up spending like a bit over 15K AUS for the kits with Motec M600 computer... since Nismo Japan does not want to sell the computer to us... they said: Either we install the car or you don't get the computer nor the engine cover nor the modified intake system.... that's why I went with MoTeC instead and will do my own intake system later on.
cheers,
richie
Old Apr 29, 2005 | 08:59 PM
  #38
ReavTek's Avatar
ReavTek
+1 for waiting for the 350EVO setup. It really seems like the best option for NA tuners.
Old May 1, 2005 | 04:22 PM
  #39
Z350Lover's Avatar
Z350Lover
ReavTek:
I think everyone is waiting for the EVO setup now... because it is purely design for the N/A tuning and I am more likely to go for this setup and hopefully can get a few extra horses out on the rear wheels...
cheers,
richie
DieselX
Videos
Jun 6, 2007 05:39 PM
SKiDaZZLe
Nov 5, 2003 03:19 PM
