Turbonetics Single Turbo Kit Group Buy
Old Jun 8, 2005 | 11:14 AM
  #201
35ounces's Avatar
35ounces
03 CS Track 6MT
A turkey call?! Curley? No Whoooooooooosh? I suppose you could replace the BOV with another.
Yeah I'd hope 425whp would be easily accomplished.
I'm still sitting on the fence between Vortech and T'netics.
Old Jun 8, 2005 | 11:16 AM
  #202
MIAPLAYA's Avatar
MIAPLAYA
Originally Posted by 35ounces
thanks for the pics, looks great. Can you hear the BOV well? Any heat issues?
Also, the numbers are good but not any better than the SC's but what is the potential with this kit? If you build the motor (or just crank it up a bit) what can you expect?
Actually I think its doing better. What is the average out of the box output of a Vortech or ATI? It thought it was in the 360 range? These ktis make around 380 out of the box. But thats besides the point. Your question was potential. The turbo is good to roughly 600 RWHP as is. the injectors will hold up to 9.5 PSI of boost before the duty cycle start approaching 100%. Turbonetics recommends no more then 9.5 PSI without bigger injectors. They are going to be offering 500 cc injectors and a flash to control them soon. It will be available as either an upgrade to current kits or as an out the door option on inital purchase. Furthermore I think Technosquare can flash for 750cc injectors so look for Turbonetics to offer those when they can. As for the turbo 600 RWHP is at 20 PSI. You could upgrade to a 62-1 physically the same size (different compressor wheel) and make closer to 700 RWHP at the same pressure level or a idea I have been kicking around with Brad is running a T66. It is not TOO much larger then the 60-1 and with some slight modification it may fit. With that turbo look for 800+ Of course you would need to be running like 1000 cc injectors and I would go to a standalone at that point.
Old Jun 8, 2005 | 11:17 AM
  #203
MIAPLAYA's Avatar
MIAPLAYA
I like the BOV sound. Theres a nice woosh there. I have vids of it if you are interested. I can dig them up. They are in the F/I forum.
Old Jun 8, 2005 | 11:26 AM
  #204
35ounces's Avatar
35ounces
03 CS Track 6MT
Thanks. Out of the box power is pretty good. I figured the potential was there.
How is this tuned anyhow? What comes with it?
Old Jun 8, 2005 | 11:37 AM
  #205
MIAPLAYA's Avatar
MIAPLAYA
For tuning it comes with 380cc drop in plug in injectors, a Walbro 255 Lph Fuel pump, and a reflash is included in the price of the kit. As for total kit contents heres the list
Turbonetics 60-1 Stage V ceramic ball bearing turbo
Turbonetics Evolution External wastegate
Turbonetics Raptor BOV
all Stainless steel Polished mandrel bent exhaust piping
All aluminum powder coated black chrome intake piping
Spearco Front Mount Intercooler
380 cc injectos (drop in plug in no new harness or cutting of stock harness needed)
Walbro 255 lph fuel pump
Turbonetics ECU reflash
One case of Turbonetics TS-1 synthetic oil
Replacement AC line (the one thats close to the turbo)
12 month/12,000 mile no fault no hassle warranty. If any part of the kit breaks it is covered with no quesitons. Even if it was your or your installers fault it is covered. No questions asked.
Old Jun 8, 2005 | 11:39 AM
  #206
dynamic6er's Avatar
dynamic6er
Green = Laww Turbonetics Turbo Kit
Red = 9psi Vortech 350Z with AAM Tuning of Split Second Box
Blue = Stock 350Z
Old Jun 8, 2005 | 11:41 AM
  #207
dynamic6er's Avatar
dynamic6er
The turbo included in the kit should be able to support 500 to 550HP but in practical applications we have not seen this happen. There are similiar physically sized turbos from Turbonetics that will offer higher boost levels and more horsepower. With a built motor there is no reason 550 to 600 wheel cannot be reached, with proper tuning and fuel supply.
Old Jun 8, 2005 | 11:46 AM
  #208
35ounces's Avatar
35ounces
03 CS Track 6MT
thanks for that Dyno!
So tuning is strictly by the ECU/reflash? No piggy back of any kind?
  #209
MIAPLAYA's Avatar
MIAPLAYA
Exactly. No piggy back. It is all handled via the ECU reflash.
Old Jun 8, 2005 | 11:51 AM
  #210
dynamic6er's Avatar
dynamic6er
If you do decide to up the boost we can custom build you a program for your setup too.
Old Jun 8, 2005 | 12:10 PM
  #211
35ounces's Avatar
35ounces
03 CS Track 6MT
I am a little concerned that the only tuning is by ECU reflash. I dont really want to have to send of the ECU everytime I do anything. At least with the Vortech ther eis the Split Second box to tweak the tune.
Old Jun 8, 2005 | 12:16 PM
  #212
MIAPLAYA's Avatar
MIAPLAYA
You actually wont have too. The ECU is cpapble of adjusting the timing for variances in airflow and environment. Perfect example here in Cali Turbonetics had a car do some dyno pulls with 91 oct in the tank. After 5-6 pulls the car was filled with 100 octane. After about 3-4 pulls the ECU started advancing the timing and the car ended up gaining another 10+ RWHP from it. And this was with the base Turbonetics reflash. That being said unless you are adding something major like cams the ECU should be able to handle whatever you throw at it.
Old Jun 8, 2005 | 02:53 PM
  #213
taurran's Avatar
taurran
The ECU reflash is a MUCH better option if you don't want to worry about tuning on a daily basis, trust me... That, and I've heard bad things about emanage and unichip piggyback setups from reputable sources.
The Raptor BoV sounds more like a WHOOOSH. No whistle. It's not TOO loud, but definitely sounds awesome from inside of the car. I wouldn't really know how loud it sounds outside, cause no one else drives my car. I'm going to have some vids up this weekend (hopefully) that show some runs. They will be posted in the FI forum, probably in a new thread.
One thing I noticed about the dyno was the low tq numbers. I dyno'd comparably low (hp wise), but for my first run I was still putting down 353ft-lbs of torque at peak. Though, your dyno does look to put out a little lower numbers than I'm used to, seeing as the stock Z only put down 216hp.
And last but not least I'd like to thank Dave for hooking us up with the Turbonetics deal. I'm extremely happy that this went through and I ended up with this kit. Thanks!
Old Jun 8, 2005 | 02:55 PM
  #214
Brandon@Forged's Avatar
Brandon@Forged
Forged Internals.com
You had 6-7 people that didn't pay? Damn! There should be some kind of penalty for that.
Old Jun 8, 2005 | 06:07 PM
  #215
35ounces's Avatar
35ounces
03 CS Track 6MT
yeah! Whats with people signing up for GB's and then not paying?
Hey this kit will work ok with the NISMO exhaust right?
Topspeed headers will survive the heat?
do I need to buy a phunk CAS wire?
Old Jun 8, 2005 | 07:46 PM
  #216
taurran's Avatar
taurran
I don't know. I was very surprised and dissapointed when it happened. I was about to jump on the APS ST bandwagon when Dave hooked up those who did pay. I'm glad it turned out the way it did.
Old Jun 9, 2005 | 10:25 AM
  #217
Alberto's Avatar
Alberto
Cranky FI Owner
Can I take the place of one of these guys that didnt pay ??
Old Jun 9, 2005 | 10:33 AM
  #218
taurran's Avatar
taurran
Hah. I wish you were interested 2 months ago! Unfortunately the deal is done and closed. AAM is a Turbonetics dealer, maybe you should talk to Dave about buying the kit.
Old Jun 9, 2005 | 02:17 PM
  #219
ECKZLNT's Avatar
ECKZLNT
haha, sure, I get impatient, and my kit comes less than to days later....
Old Jun 12, 2005 | 07:19 PM
  #220
SPRacing's Avatar
SPRacing
I Been Waiting For About A Month Or So. And Still Have Not Recieved It. I Tryed Calling Almost Everyday Now And No Answer. Please If You Can Dave, Give Me A Call At 415-407-8885
