Turbonetics Single Turbo Kit Group Buy
Old Feb 25, 2005 | 05:28 PM
  #41
thrifiddytt's Avatar
thrifiddytt
Originally posted by nis350ztt
Well, I don't think the high-flow cat version is out yet, so most likely it's the catless version. AND THIS IS THE REGULAR KIT, NOT TUNER VERSION.
You are probably right . Just don't want something minor in the future like "that fuel pump wasn't included in this kit" or "oh, you bought it in a group buy? I'm sorry you're warranty isn't valid (i.e. greddy)" or "we can't be responsible for what someone else said was going to be included that had no official affiliation with us". But I'm sure you're completely right, and if no one else cares about confirming the exact contents...then I will say no more, I promise.
Old Feb 25, 2005 | 05:31 PM
  #42
Brandon@Forged's Avatar
Brandon@Forged
Forged Internals.com
It's fine.
Dave, care to chime in to ease some thoughts of members?
Old Feb 25, 2005 | 06:10 PM
  #43
thrifiddytt
by the way, are you gonna get this kit or what? what clutch/flywheel did you end up going with?
Old Feb 25, 2005 | 06:13 PM
  #44
Brandon@Forged
This paticular one, no. The version I want isn't out yet. I'm going to go with ATS twin-plate 1150kG version and carbon coating on the flywheel.
Old Feb 25, 2005 | 06:28 PM
  #45
dynamic6er's Avatar
dynamic6er
I wasn't asking to confirm what kit it was. I was asking only him to confirm exactly what was in the kit's contents for all of the group buy participants' protection. Yeah, it's been discussed before in other threads, but this is only to be a confirmation from Altered Atmosphere, and him alone. Sorry, I've been working in the legal field too long...
This is the catless system. Turbonetics has not released the cat or tuner versions.
Old Feb 25, 2005 | 06:32 PM
  #46
dynamic6er's Avatar
dynamic6er
Originally posted by dynamic6er
Group Buy Sign-Up List:
1-350zdanny
2-thrifiddytt
3-alininger2001
4-chattermark
5-Road Warrior?
6-thrifiddytt
Old Feb 26, 2005 | 08:33 AM
  #47
Brandon@Forged
How are you going to handle the list? Like burnt350z is on the GB in the FI section, he isn't here.
Old Feb 27, 2005 | 07:17 AM
  #48
Road Warrior's Avatar
Road Warrior
sorry but i can't get in on this one.....sounds like a sweet deal though
Old Feb 27, 2005 | 05:12 PM
  #49
thrifiddytt
I'm still up in the air about it too, so don't include me right now. Wanted to check the contents of the kit. Dynamic6er Pm me the exact contents so I won't bother anyone on the thread. By the way, you listed my name twice...
Old Feb 27, 2005 | 05:37 PM
  #50
350zdanny's Avatar
350zdanny
Dave,
We are not going to make the number. How much are you selling the kit for outside the group buy? And can you list the total contents? I"m still not sure exactly what IS included with the kit. Thanks.
Dan
Old Feb 28, 2005 | 08:27 AM
  #51
dynamic6er's Avatar
dynamic6er
Originally posted by 350zdanny
Dave,
Dan
The complete install manual can be downloaded from our site.
http://www.alteredatmosphere.com/pic...oneticspdf.pdf
Old Feb 28, 2005 | 10:58 AM
  #52
xxlbeerZ's Avatar
xxlbeerZ
I like the single turbo setup, I would consider buying this. However, the ECU reflash and no cats thing seems dumb.
Old Feb 28, 2005 | 11:33 AM
  #53
ECKZLNT's Avatar
ECKZLNT
I have a question regarding the reflash: Is it going to be any different if I have any other mods (ie Plenum spacer or headers?) or will that not matter?
Also, with no cats, should there be any CELs in an 03?
I will go search thru MIAPLAYA's long thread again to see if I can answer my own questions.
Anyway, add me to the list for the GB
Old Feb 28, 2005 | 02:11 PM
  #54
Brandon@Forged
I'd like to know the answer to the first question too, just for reference sake.
Old Feb 28, 2005 | 02:21 PM
  #55
350zdanny's Avatar
350zdanny
I'd still like a price that I can buy it for outside the group buy. Thanks.
Old Feb 28, 2005 | 02:22 PM
  #56
MIAPLAYA's Avatar
MIAPLAYA
No they wont throw a CEL. As for tuning for different parts. The last I saw if you put down what other mods you have they can flash for them. Although the ECU should adjust just as your stock one would...
Old Feb 28, 2005 | 02:23 PM
  #57
MIAPLAYA's Avatar
MIAPLAYA
I'm not sure what AAM is selling it for but I know some other vendors are selling it for $4750
Old Feb 28, 2005 | 03:24 PM
  #58
Lucino's Avatar
Lucino
that's the price I have seen on a FI kit for Z/G's
Old Feb 28, 2005 | 05:31 PM
  #59
dynamic6er's Avatar
dynamic6er
Note: Because this is a general rule of thumb type thing it is always recommended that you do a baseline dyno to ensure safe operation.
Certian mods will make a difference, others will not. A turbo is not like a supercharger when it comes to changing things like headers or test pipes. Changes on the intake side will create slight changes in the A/F ratio, but they will need to be pretty extreme to cause a significant change in A/F. (ie- port and polish, larger valves, cams, etc.) Changes on the exhaust side will make the motor slightly more efficient (headers), but this will show mostly in the spool characteristics of the turbo. The mass air meter is also able to account for slight changes in air volume due to additional modifications. Again, to be 100% positive that your motor is operating in a safe A/F range you must log your A/F ratios under load at wide open throttle with a wideband on a dyno or on the street.
There should not be any CEL lights due to O2 sensors or otherwise, but again, this is not a stock vehicle once the kit is added. This means that it WILL be higher maintaince, may occasionally hiccup, and may set off a CEL. This can be caused by emmission systems malfunctions, misfires, etc. etc. 9 times out of ten if the kit is installed properly, the car is cared for religiously, and not beat on 100% of the time then the reliability should be very good and potential for problems should be minimal.
Sorry for the late reply. Hope that helps!
Old Feb 28, 2005 | 05:34 PM
  #60
dynamic6er's Avatar
dynamic6er
One thing should be noted. The majority of vendors offering this price are not Authorized Turbonetics Dealers. I hate to be a stickler on this point, but personally the 12 Month/12,000 Mile Warranty is what makes this kit. (and the engine management )
