stock clutch and moded flywheel?!?
Old Mar 16, 2005 | 06:28 PM
COJ_General's Avatar
COJ_General
Question stock clutch and moded flywheel?!?
Im not sure whether this is a dumb question or not, but please try and help out! and I did some searches but it didn't seem like anything useful was coming up....well, my transmission is gone! destroyed! THANKFULLY it is covered by the warranty....so thats not a problem. As well, they are going ahead and replacing the clutch as well...now nissan had informed me that they will check out the flywheel as well, and see whether it is good or not. If not, then I will have to replace it with a new one at my cost....so naturally i figured if thats something i would be changing around anyway, I might as well get an aftermarket one. But thats where my question comes up....is it possible to stay with the stock clutch and go with the tilton flywheel for example? that was something i wasn't sure about so i wanted to ask before so that i could prepare to either buy an aftermarket one or if i would have to stay with nissan. As well, going with this setup for now (I don't have enough to replace both clutch and flywheel), what would be the best flywheel to put on? I don't believe I'll be going with FI, so what would be my best option? Thanks alot.
Old Mar 16, 2005 | 06:44 PM
EdgeOfSanity's Avatar
EdgeOfSanity
You cannot run the tilton flywheel with the stock clutch because the tilton flywheel has a smaller diameter. However you can run the stock clutch with any aftermarket flywheel that has the stock diameter such as the jwt, nismo, and UR flywheels.
Old Mar 16, 2005 | 07:15 PM
COJ_General
awesome!!! thanks alot! for price, what is the best one to go with?
Old Mar 16, 2005 | 09:08 PM
EdgeOfSanity
The best deal out there is the jwt clutch and flywheel imo. If you look around you can easily get the combo for less than $800 shipped. When i go in for my next warrenty tranny its what i'll be installing in my car.
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
