What should my next mod be??
Old Apr 14, 2005 | 05:11 AM
tommym's Avatar
tommym
Default What should my next mod be??
Sup guys,
mods so far are:
Gruppe-s Y pipe
popcharger
AAM angled spacer
UR crank pulley
what should my next mod be? I am kind of wondering if I should just finish up the exhaust??
what do you guys think?
Thanks
Old Apr 14, 2005 | 05:30 AM
Machupo's Avatar
Machupo
if you're budget conscious: upgrade your brake lines, pads and fluid (SS braided lines, ATE Superblue fluid, and pads depend on your application / noise tolerance)
if money is no object: lightweight flywheel and clutch
Old Apr 14, 2005 | 05:52 AM
tommym's Avatar
tommym
definately on a budget...that is why i have the cheaper mods...hehe. I am thinking of going with the hawks pads...seem to be the best.
Old Apr 14, 2005 | 05:54 AM
xephiron's Avatar
xephiron
I assume you mean horsepower upgrade? I would go with test pipes next, or high flow cats perhaps if you are worried about emissions or being too loud? That is the bottleneck you are looking at for air flow (in or out) sinced you already upgraded the rest. Headers and Exhaust can help too, but I would address the most restrictive part left on your system first... those 4 stock cats.
Here is another suggestion if you wanna do brakes: Stop-tech also makes a nice and cheap brake upgrade for non-bembro's which will eliminate your fade and really upgrade your braking feel and overall performance... Stage 2, it comes with SS lines, Motul fluid, cross-drilled rotors (stock size, can also opt for slotted) and some Hawk APS pads. All for around $650 I think, check here:
http://performancenissanparts.com/ca...oducts_id=3424
Good luck
Old Apr 14, 2005 | 06:30 AM
tommym's Avatar
tommym
i didn't even know stop-tech had the upgrade. thanks for the info. i was thinking about test pipes, but i wonder about raspiness that i keep hearing about with them. would there be a noticable difference with them?
Old Apr 14, 2005 | 09:58 AM
xephiron's Avatar
xephiron
It is a matter of opinion, you really gotta hear it to judge that for yourself... rasp to me is a Honda Civic with a coffee can sticking out the back. 350z with headers/tp's/exhaust is more of an exotic sounding (yes typically pretty loud) and it only seems to happen around 4k RPM's. Really kinda reminds me of a ferrarri or something. I like it personally, but many do and many don't so try to hear some in person. I wouldn't rely on sound clips either.
Stevo Z
Oct 3, 2015 09:14 PM
Dymsi
Sep 29, 2015 11:32 AM
Tochigi_236
Sep 27, 2015 03:40 PM
