Heads: Port & Polish?
Old Apr 16, 2005 | 01:39 PM
Silverton's Avatar
Silverton
Default Heads: Port & Polish?
Has anyone tried porting and polishing the heads? Also, has anyone tried the Nismo VQ35 46cc heads? These heads do raise the compression ratio but I don't know how much.
Old Apr 16, 2005 | 03:08 PM
Tex Willer's Avatar
Tex Willer
Someone at performance nissan has portpolished heads, Jason maybe.
I'm thinking of doing it next year, along with cams, valves and springs
takes a P&P wizard to do it right though... someone who has done this for better part of his life for serious applications. I wouldn't thrust anyone else
Old Apr 16, 2005 | 03:13 PM
g356gear's Avatar
g356gear
Some of the guys who just got their built motors up and running are seeing restrictions with the stock heads and cams past 500-520 hp....even when adding more boost. In these situations the port and polish with cams will get the engines closer to the 600hp level I think.
Old Apr 16, 2005 | 05:28 PM
G3po's Avatar
G3po
Default heads
My expectation is that just adding JWT S1 cams (or similar) "alone" can net > 40rwhp beyond the levels being seen with stock heads and Cams at the same higher boost levels.
Old Apr 17, 2005 | 01:11 AM
axxizzer's Avatar
axxizzer
I would doubt it...Although I have no experience with those cams: NOTHING makes that much power on our cars...
never mind, just read the boost leve things = youre turbo = things CAN make crazy power.
hulkout
Tuning
Sep 30, 2015 12:33 PM
