ANYONE know how to adjust Cusco LSD???
Old Apr 18, 2005 | 08:21 PM
formulaZ's Avatar
formulaZ
Default ANYONE know how to adjust Cusco LSD???
hi peoples,
i was able to win an auction for a cusco rs lsd. i have it here, but now i do not have any instructions with it. i was wondering if an of you knew how to adjust the damn thing. i know it comes in at 100% lockup and i know i need to rearrang the plates somehow. anyone know how or at least have a diagram? i would greatly appreciate the help.
thanks
Old Apr 18, 2005 | 10:13 PM
Brandon@Forged's Avatar
Brandon@Forged
Forged Internals.com
Please post about driving impressions when you drive it. I want a better than OEM LSD that isn't going to make noise.
Old Apr 19, 2005 | 02:33 AM
Machupo's Avatar
Machupo
Originally Posted by formulaZ
hi peoples,
thanks
i'm rather positive that you don't need to rearrange the plates, i'm pretty sure there is an easy way to switch between the settings -- i'll have to check mine out when the rear end arrives
edit: ok, just looked it up and though i haven't found directions, found that you can only change it during an overhaul, so it sounds a bit more complicated than i thought (more towards rearranging plates) -- my directions are in japanese, so it's slow-going in figuring it out!
Old Apr 19, 2005 | 03:37 AM
one3502nv's Avatar
one3502nv
The Nismo LSD is the only one that is "easily" adjustable... I believe all other lsd's require plate rearrangement as stated... Try calling Z1 in NY. I believe they are big cusco dealers..
Old Apr 19, 2005 | 03:45 AM
aalzuhair's Avatar
aalzuhair
yes, you must rearrange the plates in order to change the lookup, but leave it as is ... its fine.
Az
Old Apr 19, 2005 | 02:31 PM
daytona350z's Avatar
daytona350z
Az
does it pop or shudder when you are making slow tight turns?
thanks
Old Apr 19, 2005 | 02:36 PM
formulaZ's Avatar
formulaZ
thanks for the help. if you find the directions at all, could you please let me know. i would gladly pay for a copy and postage on it.
thanks
Old Apr 19, 2005 | 10:05 PM
MY350Z.COM's Avatar
Isn't going to make noise? Hah, good luck. If you want a clutch-type LSD then you will get noise.
Old Apr 20, 2005 | 06:38 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Not true.....the NISMO is actually the same unit as the Cusco MZ. Both are adjustable for LSD action (1.5 way to 2 way) via the cam adjustment on the side of the diff - very easy. The RS verison steps this up by having a sprung hub - makes for less noise, and much smoother engagement compared to a solid hub design (ala KAAZ and NISMO). To change lockup % though, the disks much be rearranged
Old Apr 20, 2005 | 09:16 PM
aalzuhair's Avatar
aalzuhair
thanks
I did pop, but that was before the RedLine oil (refer to sig), which you should use with this LSD
Old Apr 21, 2005 | 03:54 PM
formulaZ's Avatar
formulaZ
humm. not from what i have driven. the cusco rs is by far one of the best lsd's when it comes to noise. a friend of mine has one on his z and it is very quiet. his lockup is 100% as well, but then again he pushing 420whp.
RiujinZero
Sep 25, 2015 01:19 PM
