Stillen Cam
Old Apr 19, 2005 | 01:04 PM
C5DEMON's Avatar
C5DEMON
Default Stillen Cam
Has anyone tried this???
Stillen's site:
"S1 BILLET CAMS ADD 15+HP WHILE MAINTAINING EXCELLENT DRIVABILITY AND IDLE QUALITY. THE INTAKE AND EXHAUST CAMS BOTH HAVE THE SAME LIFT AND DURATION SPECS, 260 DEG DUR. / .428"(10.9MM) LIFT, INT. ADVANCED 2 DEGREES. DESIGNED TO USE WITH STOCK SPRINGS."
$1335.00
Anyone have it? Is it better than the Nismo? JWT?
Where can I find the Tomei cams?
Old Apr 19, 2005 | 01:07 PM
mario60185's Avatar
mario60185
Chicago Realtor
never heard of anyone. been here forever.
Old Apr 19, 2005 | 01:12 PM
MIAPLAYA's Avatar
MIAPLAYA
JWT usually refers to their cams as S1, S2, S3, etc...these are probably JWT cams...
Old Apr 19, 2005 | 03:16 PM
G3po's Avatar
G3po
Default Stillen Cams
The Stillen quote is the same verbatim from the JWT site.
You can gettem cheaper elsewere.
Old Apr 19, 2005 | 04:51 PM
Z350Lover's Avatar
Z350Lover
Wow... with the lift up to 10.9mm.... I think the stock springs will get compressed entirely and the valves might be hitting the pistons real bad though.... I needed to change those stock springs when fitted with nismo s1 cams and the lifts are 10.7mm and 11.0mm. So I think the stock springs shall be replaced in this case?
cheers,
richie
Bodyboarder81
Nov 2, 2015 12:17 AM
kyin
Oct 15, 2015 05:54 AM
Nicky R
Sep 20, 2015 01:05 PM
