Fuel lines...
Old Apr 23, 2005 | 06:15 AM
Brandon@Forged's Avatar
Brandon@Forged
Forged Internals.com
Default Fuel lines...
What is the size of the fuel lines on the 350Z? Is it 3/8" NPT?
Also, does anyone know where the hell that hawker racing battery thread is? I searched for "battery", "hawker battery", and "racing battery" and it didn't come up with that thread.
Old Apr 24, 2005 | 10:49 PM
Brandon@Forged
Bump.................
Old Apr 25, 2005 | 01:41 AM
teh215's Avatar
teh215
There are no pipe threaded fittings in the OEM fuel system but, if you are adding something like a pressure gauge, you are probably going to need a 1/8-27 NPT tap.
I don't know about the battery thread but, I too looked and just looking for "hawker" I could only find this tread and one other.
Old Apr 25, 2005 | 02:46 AM
Brandon@Forged
Well, I am planning on doing some experimenting with a fuel cool can, I was going to take the fuel lines that go to the fuel rails and run them to the cool can and then run new lines to the fuel rails.
Yeah, I was just trying to find out which battery it is.
Old Apr 26, 2005 | 12:39 AM
MySunset350Z's Avatar
MySunset350Z
its "odyssey" that you want to look up. if i remeber correctly the battery weighed between 12 and 14lbs depending on which one you got. if your looking to buy one, get the PC680. there is 1 other odessey lighter then the PC680 by 2lbs, but the cranking power isnt anywhere near the PC680. saves 22lbs+ over the stock battery.
Old Apr 26, 2005 | 03:08 AM
Brandon@Forged
Hawker Odyssey or are you talking about another brand? Thanks btw.
