new project
Old Apr 27, 2005 | 10:51 PM
newbie's Avatar
newbie
Default new project
gonna rev up my engine to 7300rpm, and wondering if upgrading con-rod and high strength valve spring is good enough?
thanks
Old Apr 27, 2005 | 11:00 PM
vegasedge's Avatar
vegasedge
Its all about Harmonics at higher rpms.
Old Apr 27, 2005 | 11:12 PM
ReavTek's Avatar
ReavTek
You need new rod-bolts. I hear u can run stock con-rods with upgraded rod bolts up to 7200rpm. However, for piece of mind the con-rods should be replaced. Pauter, Crower, and a few others make con-rods for the VQ35DE.
Old Apr 28, 2005 | 08:41 AM
350Zteve's Avatar
350Zteve
thanks
What are you doing to the motor to take advantage of the higher rpms? To make power up there, you should do cams and an plenum at least. Port the heads too if its in your budget.
Also, if its in your budget, go with some aftermarket rods and pistons so you can rev to 8,000.
Old Apr 28, 2005 | 11:52 AM
GY-Z's Avatar
GY-Z
con-rod, con-rod bolts, and high strenght spring valve should do the trick.
350Z_Al
Oct 29, 2020 07:44 PM
Dymsi
Sep 29, 2015 11:32 AM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
