110 octane in Z, good or bad?
Old May 7, 2005 | 04:38 PM
DayBlueZ's Avatar
DayBlueZ
Default 110 octane in Z, good or bad?
Will putting 110 octane in my stock Z do harm? Will it do any good as far as power increase?
Try it or waste of time?
Old May 7, 2005 | 04:52 PM
Armitage's Avatar
Armitage
Waste of time unless you have the ECU programmed to take advantage of it.
My understand is that a higher octane rating simply is more prone to resist detonation. By simply adding higher octane fuel, especially that high, you won't notice much of a difference.
Old May 7, 2005 | 05:08 PM
350Zteve's Avatar
350Zteve
I sure hope its unleaded. I've never seen unleaded with octane over 104
Old May 7, 2005 | 10:47 PM
ReavTek's Avatar
ReavTek
Would running leaded fuel damage the motor?
Old May 7, 2005 | 10:50 PM
sentry65's Avatar
sentry65
the burninator
yes it would
it'd ruin your sensors
why do you guys need 110 octane?
if anything you'll LOSE power because there won't be enough compression in the piston chamber to get good spark ignition
if you go out to the track and are going to be running really hard, then run 100-103 octane
NEVER LEADED octane unless you have a race engine designed to run on leaded gas - probalby one that doesn't have fancy computer sensors....
Old May 7, 2005 | 11:05 PM
350Zteve's Avatar
350Zteve
Not the motor. It's kills O2 sensors after a while and kills catalytic converters quickly.
Old May 8, 2005 | 01:24 AM
jreiter's Avatar
jreiter
That's right. The computer can only advance the timing a certain amount. Once you're running an octane that causes no knocking at all, the computer will have advanced timing as far as it can. After that, continuing the increase the octane further will make no difference at all. 93 octane is probably the magic number on a 350Z where you'll get zero knocking. Beyond that and you're wasting money.
Justin100
Nov 25, 2021 06:26 AM
Jambo016
Sep 16, 2016 01:08 PM
