Does oil pressure drop after an install of a higher capicity oil pan?
Old May 22, 2005 | 09:07 PM
Rickdogg's Avatar
Rickdogg
Out of hiatus
Exclamation Does oil pressure drop after an install of a higher capicity oil pan?
I just got a ARC Oil pan installed, which holds an extra quart and my Defi Oil Pressure gauge started beeping and reading lower oil pressures than before. Is this normal?
Used to read about 39 psi at idle and now reads about 30 psi
Old May 22, 2005 | 09:15 PM
uplz4588's Avatar
uplz4588
39 psi at idle! My OEM guage reads at like 20ish or 25
Old May 23, 2005 | 03:35 PM
Rickdogg's Avatar
Rickdogg
Out of hiatus
Anyone?
Old May 23, 2005 | 03:45 PM
nismo33's Avatar
nismo33
BoNe SToCK BaSe
i know stupid question but sometimes people miss the obvious. did you add the extra quart after it was installed? maybe the guy that installed it use the regular amount after installing the oil pan. just a thought.
Old May 23, 2005 | 04:08 PM
Rickdogg's Avatar
Rickdogg
Out of hiatus
Ahh, should have clarified. Yes, there was 6 quarts added and I even added an extra 1/2 quart when I noticed the pressure drop
Old May 23, 2005 | 04:16 PM
g356gear's Avatar
g356gear
A high capacity pan should not change your oil pressure unless the pick up has been extended. That would mean a longer distance for the oil to travel up to the pump which may drop overall pressure slightly...but not a lot.
Old May 24, 2005 | 08:00 AM
nismo33's Avatar
nismo33
BoNe SToCK BaSe
it may be the sending unit, if the gauge is after market
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
