$500 To Spend What Sould I Get???
Old May 22, 2005 | 10:21 PM
TheNiNi's Avatar
TheNiNi
Default $500 To Spend What Sould I Get???
Hey i just got $500 to spend on my car what should i get???
i already have a popcharger motordyne plenum spacer and ground wire kit
i was thinking about a UR crank pulley or pulley set what do you guys think??
Old May 22, 2005 | 10:36 PM
djbit's Avatar
djbit
Hotchkis springs and sways. I lot of people worry about making a car faster but why not go for a mod that will drastically change the feel of the car (in a good way).
Old May 22, 2005 | 10:52 PM
Jaki's Avatar
Jaki
The UR pulley set is a good mod.
Old May 22, 2005 | 10:57 PM
TheNiNi's Avatar
TheNiNi
sould i get just the crank pulley and Gruppe-S Y-Pipe??
Old May 22, 2005 | 11:59 PM
TheNiNi's Avatar
TheNiNi
and dose any one know if the y-pipe is hard to install??
and if you get anymore HP or TQ from just the crank pulley or the 3pcs pulley set?
Old May 23, 2005 | 01:20 AM
350ZYALATA's Avatar
350ZYALATA
Tentill4z
Yes you do get more hp and Tq from the pulley set I have a set of UR pulleys and gained 12 hp and 9 lb-ft and it increases as you modify the car because less power is being robbed and the lightened weight frees it up oh and this is not a DIY if you don't have the proper tools and equipment plus you have to lift the car.
Old May 23, 2005 | 02:00 AM
TheNiNi's Avatar
TheNiNi
o ok cool well has dose any one have a gruppe-s y-Pipe??
if anyone dose please tell if you like it and if there was any power gain
Old May 23, 2005 | 06:54 AM
Zquicksilver's Avatar
Zquicksilver
All good suggestions...
12hp is impressive for the pulley set...??? Your FI, right?
Hotchkis setup is nice too, nothing like a better handling Z!
If you want some good HF cats for $445 shipped, check out the HELIX HF cats from either HOPUPRACING or I M Racing...200 CEL metal substrates/internals will not collapse like others. Figured you have the breathing mods on the front end...
Zquicksilver
Old May 23, 2005 | 07:20 AM
Machupo's Avatar
Machupo
A good set of High-flow cats (Crawford or Ultimate-Racing)...
you'll get a nice power boost out of them, and even more with each additional breathing mod you make.
Old May 23, 2005 | 01:29 PM
TheNiNi's Avatar
TheNiNi
Will HF Cats void my warrenty?
Old May 23, 2005 | 02:28 PM
zxsaint's Avatar
zxsaint
Fairlady Stalker
+1. Machupo knows what he's talking about. Cats and Y-pipe are the next stage.
No, they won't void the warranty.
Old May 23, 2005 | 03:00 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Best bang for the buck imo, and if you dont mind swapping in your cats for your sniffer test Id recommend:
1. Test pipes, better gains than HF cats at less than 1/2 the cost, get resonated one's if you dont want rasp. I got some for $180 off ebay average is $250
2. Get a UR crank pulley, I have one I recommend it, you can definetely feel it. You should be able to get one for $220 or so with belts. Around $200 for just the pulley.
3. Take the extra money if you have some and find a local dyno and see where you stand-I get 3 pulls with a/f on a dynojet for $60....
Good luck, whatever you choose Im sure you'll be happy with it.
Old May 23, 2005 | 05:27 PM
Rickdogg's Avatar
Rickdogg
Out of hiatus
Pullies and test pipes.
AbrasiveRaysive
Sep 20, 2021 02:29 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
Nicky R
Sep 20, 2015 01:05 PM
