Auto Tranny POwer Handling
Old May 27, 2005 | 10:22 AM
blackroadster's Avatar
blackroadster
Question Auto Tranny POwer Handling
Hey how u all doin? I called the guys at Turbonetics for info. on their single turbo kit and a tech told me it wasn't recommended because of power handling limitations of the automatic tranny. Anybody else know if it's true? Stillen has this new upgrade for it http://www.stillen.com/Sportscars_de...d=47326&page=1 any thoughts?
Old May 27, 2005 | 10:50 AM
DOHC's Avatar
DOHC
Cool
Several FI makers (Vortech, Stillen, etc.) do not make a blower kit for the AT cars. There must be a reason......note that the Stillen valve body kit does not mention that it keeps the trans from breaking, just that it will "increase the power handling ability of the trans", whatever that means. I'd love to put a Stillen blower on my Z - I have two other FI vehicles now - but not with that AT....
Old May 27, 2005 | 11:06 AM
Sins4u33's Avatar
Sins4u33
I dont see the problem, just long term problems down the road im running my ati procharged on the 5at and my friend is currently running his vortech unit on his 5at, we haven't had any problems what so ever, just a longer lag between shifts, we both are pushing over 370-405whp and the tranny is still holding up, even under extreme loads and runs. The valve body is very beneficial, i would imagine for even n/a applications...
Ben Y
AAM
Old May 27, 2005 | 12:28 PM
PumpedVA's Avatar
PumpedVA
My tranny went out with FI but I dont know if FI was the reson just happend after I installed it. about 6-10 months after
Old May 27, 2005 | 02:00 PM
Aggro_Al's Avatar
Aggro_Al
Vortech, Stillen etc. do make FI for the 5AT. In most instances turbos tend to work better on an auto tranny. With the exception of space restrictions, I don't see a reason why you couldn't put a SC or turbo on the 5AT if it also works on the 6MT. Chances are that if it is too powerful for the AT without a build-up, it also too powerful for the 6MT without a build-up.
Old May 27, 2005 | 02:58 PM
bwzabodyn's Avatar
bwzabodyn
1) Best F/I for 5AT = Turbo
2) Before VB upgrade:
5AT = 350hp flywheel
After VB Upgrade:
5AT = 450-500WHP
Old May 27, 2005 | 04:23 PM
zzzya's Avatar
zzzya
I have the Level Ten torque converter and valve body upgrade installed and it is quite nice for NA and I was told by Level Ten that these upgrades would allow the tranny to support 600rwhp from their testing. I have found thus far that a tranny cooler isn't actually necessary, but if I went FI, I would add one for sure. The tranny fluid does currently run through the stock radiator to help cool the fluid, so one way of knowing whether a tranny cooler is needed is to watch for an increase in temp on the general cooling system gauge.
Old May 28, 2005 | 09:09 AM
Q45tech's Avatar
Q45tech
JATCO [oem manufacturer] specs the 5AT used in Q45/M45/ G35 at 333 lb/ft max peak [ocasionally] not every shift is WOT...........340 HP at 6300 rpm = 284 lb/ft...........15% safety factor delivers the 100,000 mile plus life. 380HP at 6300 would be 100% of rating so guessimate that life might be reduced by 3/4 [at least].
Transmissions just expendible $4500 [rebuilds] replacement items when you exceed oem power often or by much.
Old May 28, 2005 | 09:27 PM
kinjal's Avatar
kinjal
Default your mods
how much did you pay for parts and install for the torque converter and valve body? pm me or reply here please. thanks!
Old May 28, 2005 | 10:30 PM
zzzya's Avatar
zzzya
Parts were about $1300 and I installed them myself.
Old May 30, 2005 | 07:17 PM
blackroadster
damn those upgrades are expensive....the single turbo kit goes for 4800 plus misc. items, fluids, etc. I will install them myself with my mecanic friend at least...
Old May 30, 2005 | 08:01 PM
zzzya's Avatar
zzzya
They are but much like a clutch in a 6MT, they are necessary for longevity and better performance from the tranny with high HP. Even on an NA car you feel the difference as shifts are solid and fast when on the throttle.
Old Jun 2, 2005 | 07:49 AM
turbo_toys's Avatar
turbo_toys
Turbo Toys Inc.
If you dont want any down time on you car, and want to get one built,I have a couple of auto trannies for sale
Jim
813 6956664
burglapfd
Dec 6, 2020 01:04 PM
350Z_Al
Oct 29, 2020 07:44 PM
Jambo016
Sep 16, 2016 01:08 PM
