About to install UR Crank Pulley, reset ecu?
Old Jun 6, 2005 | 08:20 AM
DayBlueZ's Avatar
DayBlueZ
Default About to install UR Crank Pulley, reset ecu?
In the UR manual it says results won't be seen until the ECU resets in 5-7 days. Can i just disconnect the battery for 12 hours and do the same thing? DO i have to wait 5-7 days to notice HP increase or is that BS?
Old Jun 6, 2005 | 08:42 AM
DavesZ#3's Avatar
DavesZ#3
I'm wondering why you would even need to reset the ECU. I can see the ECU needing to be reset after mods that affect fuel, air, exhaust flow or timing but I can't see where the ECU would have anything to do with a change such as the crank pulley.
It's like changing your clutch out for a lightweight one, the performance gain should be immediate since all you're doing is freeing up HP to the wheels. Doesn't that make sense?
Old Jun 6, 2005 | 09:32 AM
DayBlueZ's Avatar
DayBlueZ
In the manual for the Pulley, it says :
The Maximum HP gains from the pulley/s can be expected within 5-7 days of driving, once the computer has recalibrated fully and taken advantage of the engines lighter rotational weight.
I wasn't sure if i could do it the easy way or had to wait for it. Or, if it was just a line of BS.
Old Jun 6, 2005 | 09:34 AM
Alberto's Avatar
Alberto
Cranky FI Owner
I never reset my ecu for any of my mods, including my pulley, so I would say no, dont worry about it. After I put my pulley on I leaned waaayyyy out, I know it doesnt make sense but MY car with MY mods ran way lean after I put the cp in for some reason.....
Old Jun 6, 2005 | 09:58 AM
DayBlueZ's Avatar
DayBlueZ
What did you do to correct it?
Old Jun 6, 2005 | 11:31 AM
jcpeyton's Avatar
jcpeyton
subscribing
Old Jun 6, 2005 | 03:07 PM
black350's Avatar
black350
subscribingx2
Old Jun 6, 2005 | 04:58 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Reflashed my ecu. I went from high 13's a/f to very very lean over 15:1.....the dyno shop said they had never seen that happen before with a mod such as a pulley, but hey you know how our ecu's are. Now car runs great Not trying to scare you just letting you know what happened with MY Z.....
Old Jun 6, 2005 | 11:34 PM
DayBlueZ's Avatar
DayBlueZ
I'm going to Dyno after i install my mods.
That way i will know.
Old Jun 7, 2005 | 04:42 AM
cox's Avatar
cox
The crank pulley fits on the 35th anniversary?
Thanks for your reply..
Old Jun 7, 2005 | 05:30 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
yes...fits on all Z's
no need to reset the ecu...just drive as you normally would
Old Jun 7, 2005 | 02:22 PM
cox's Avatar
cox
Thank you very much Z1...
Grazie mille...
Old Jun 7, 2005 | 05:00 PM
jcpeyton's Avatar
jcpeyton
A question +/- on topic- I have a KJR lightweight crank pulley on order; it is not undersized. Are UR's non-crank pulleys, i.e. water pump and a/c undersize or OEM? If these secondary pulleys are OEM size, and just lightweight, will installing them result in additional gains? Will UR sell the secondary pulleys separately? Anyone have experience w/ this? Thanks.
Old Jun 7, 2005 | 05:24 PM
DayBlueZ's Avatar
DayBlueZ
There are no additional gains with the other pulleys. The only gains are seen from the crank pulley.
Old Jun 7, 2005 | 05:30 PM
jcpeyton's Avatar
jcpeyton
Thanks, DayBlueZ. I kinda figured that was the case, but wanted confirmaton from those more experienced.
Fixxxercask
Nov 9, 2015 11:10 AM
