KJR pulley installed-first impressions
Old Aug 21, 2005 | 03:05 PM
DavesZ#3's Avatar
DavesZ#3
All I can tell you is it's hard, very hard. If you have a MT, you have to have it in 6th gear and it helps to have somebody stand on the brakes. If you have an AT, from what I recall reading, your best bet is to try the "crank the engine" trick.
Old Aug 21, 2005 | 03:51 PM
jcpeyton's Avatar
jcpeyton
+1 on the VERY hard. We ended up wrapping plastic-coated aircraft cable 3x around the pulley, then wrapping the tail of the cable around the sway bar 2/3x, just to keep the crank from turning. As i recall, it's a right-hand bolt. We used a 2 foot breaker bar from underneath, with the car on a lift. It was a bastard, but the bolt finally broke loose.
Old Aug 21, 2005 | 04:08 PM
DavesZ#3's Avatar
DavesZ#3
Another thing - you can't pop it loose by just pulling on the breaker bar. You'll need a couple of sharp jerks to get it to come loose. Slow steady pressure just causes it to slowly turn over the engine/transmission/wheels.
Old Aug 21, 2005 | 04:22 PM
jcpeyton's Avatar
jcpeyton
Yep. An impact wrench would be ideal, if you could get it in there. We tried, but couldn't find room, even w/ the fans removed.
Old Sep 17, 2005 | 01:26 PM
kamikaZ's Avatar
kamikaZ
3FIFTYZ
I am prob. going to order this now, I know I am going to forget to check up on the bolt so hopefully everything will hold tight.
Old Sep 26, 2005 | 01:04 PM
kamikaZ's Avatar
kamikaZ
3FIFTYZ
got mine, looks stock, sounds stock, runs a little better...I like
Old Sep 26, 2005 | 02:24 PM
Z BOY's Avatar
Z BOY
protocav installed mine in his garage without removing the fan. he said it wasn't necessary. he did remove the top engine cover and strut bar, tho. install time for him: about an hour.
Fixxxercask
Nov 9, 2015 11:10 AM
NissanZcrazy
Sep 23, 2015 07:59 AM
Calinismo350z
Sep 14, 2015 04:04 PM
EnjukuRacing
Sep 11, 2015 08:34 AM
EnjukuRacing
Sep 11, 2015 08:30 AM
