Shift Knob keeps on twisting...what to do?
My Shift **** keeps on twisting to the right whenever I do a run causing me to miss 2nd at times. I want to tighten it up.
Is there a "elegant" way of fixing this?
any thoughts?
ps. I like the stock shift know a lot so getting a new one is not an option
any thoughts?
I know what you can do. Keep twisting it till it is tight and lines up. It is a nylon threaded **** so just keep turning it righty tighty till it is tight enough. I would recommend using pliars to hold the shifter while you twist the ****.
Performance Nissan
Performance Nissan
the problem is the stock shift **** has tons and tons of lock tite one it...
I do not recomend doing what king tut says.. you will tear the shift boot...
I recomend getting a new shift ****... it comes with the thread lock already applied...
http://performancenissanparts.com/ca...oducts_id=1062
Originally Posted by CLETUS
this may sound dumb but why not take it to nissan and let them put a new one on under warranty??? how many miles are on your 05?
Not worth the hassle.
I'll try the locktite method first and if that doesn't work I just buy a new ****
Thanks everyone!!!!
MAsSIVrOOM
Oct 20, 2023 10:50 AM
HoneyBadgerRy
Sep 21, 2015 03:25 PM
