Changed AT5 pumpkin for a 6MT pumkin..got CEL
Old Jun 20, 2005 | 02:07 PM
booger's Avatar
booger
Default Changed AT5 pumpkin for a 6MT pumkin..got CEL
Ok..I changed out my open AT5 rear end for a 6MT LSD . Every thing seems fine but Ive gotten a CEL a couple of times....1574 code . Any one get this code , or know what it could be ?
Old Jun 20, 2005 | 03:27 PM
westpak's Avatar
westpak
SFZCC
DTC P1574 ASCD VEHICLE SPEED SENSOR
The ECM receives two vehicle speed sensor signals via CAN communication line. One is sent from unified meter and A/C amp., and the other is from TCM (Transmission control module). The ECM uses these signals for ASCD control. Refer to EC-647, "AUTOMATIC SPEED CONTROL DEVICE (ASCD)" for ASCD functions.
DTC Detecting Condition: ECM detects a difference between two vehicle
speed signals is out of the specified range.
Possible Cause:
 Harnessor connectors (The CAN communication line is open or shorted)
 Unified Meter and AC Amp
 ABS actuator and electric unit (control unit)(models without VDC)
 VDC/TCS/ABS control unit (models with VDC)
 Wheel sensor
 TCM
 ECM
Old Jun 20, 2005 | 03:30 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
Did you do the swap yourself?
Old Jun 20, 2005 | 03:38 PM
jcpeyton's Avatar
jcpeyton
subscribing
Old Jun 20, 2005 | 03:57 PM
g356gear's Avatar
g356gear
I did the swap as well. You have to make sure both speed sensors are seated properly in their spots and tightened down properly. They have to be within a certain distance of the axle to recieve accurate data. Also make sure both sensor clips are properly seated and locked together.
booger's Avatar
booger
Possible Cause:
 Wheel sensor
 TCM
 ECM
Thanks...But it is way over my old head . So it just may be the speed signals from the Tranny and the rear end that are different and that is causing it ?
And No...I didnt do the install the shop I use did it
Old Jun 20, 2005 | 03:58 PM
booger's Avatar
booger
I'll look up the locations in the manual and check them ...THANKS
Old Jun 20, 2005 | 04:00 PM
BluZee's Avatar
BluZee
I had no problem with my swap. Im wondering if one of the sensors is loose.
Old Jun 20, 2005 | 04:52 PM
zachcrosen's Avatar
zachcrosen
Booger, what are your impressions of puting the 6MT pumpkin in a 5AT F/I car? I have a friend who has a 6MT HSK SC Z who wants to swap with me but I have not read a lot about puting the 6MT gearing in a 5AT F/I Z. Any opinions would be greatly appreciated.
Old Jun 20, 2005 | 04:59 PM
juan's Avatar
juan
westpak, where did you get the write up?
Old Jun 20, 2005 | 05:04 PM
westpak's Avatar
westpak
SFZCC
It is from the manual.
Old Jun 20, 2005 | 05:21 PM
booger's Avatar
booger
A little faster excel . Havent really flogged the car at all to really find out . On the dyno Im at 90mph at 6900rpm and I used to be at 105mph in 3rd gear
Old Jun 22, 2005 | 12:33 AM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
disconnect the battery did you? befor installing that is...
Old Jun 22, 2005 | 02:57 PM
black350's Avatar
black350
subscribing
Old Jun 22, 2005 | 03:52 PM
booger's Avatar
booger
That I wouldnt know....if the shop did or not..why ?
lapham3
Oct 7, 2022 03:15 PM
Stevo Z
Oct 3, 2015 09:14 PM
Fixxxercask
Drivetrain
Sep 28, 2015 11:15 AM
