Unorthodox Crank Pulley cause of A/C failure?
Old Jul 18, 2005 | 11:32 AM
SinCity350Z's Avatar
SinCity350Z
Track Whore
Default Unorthodox Crank Pulley cause of A/C failure?
After installing my Unorthodox Racing Crank Pulley my A/C wasn't blowing cold. I took it for a smog check and had the Jiffy Lube guys check the A/C while I was there. They said that the compressor was shot. Could this happen because of the underdrive pulley or is it just a coincidince? I really need the A/C because it has been 115+ here in Vegas for the past couple of days. Thanks.
Old Jul 18, 2005 | 11:53 AM
narkotic's Avatar
narkotic
You'll probably never know, although I highly doubt it.
Do we have any data that will show how much slower the compressor is spinning? I don't think within the RPM decrease it would over-heat a compressor.
I do know that you will probably have issues getting it replaced under warranty due to the pullies, you could try to put your stock pulley back on but they will know that it was replaced previously.
Good luck with that one!
Old Jul 18, 2005 | 11:57 AM
SinCity350Z
Track Whore
My warranty is up anyway. Thats why I am trying to figure it out on my own. The Nissan dealer here wants $1300 for parts and labor!
Old Jul 18, 2005 | 01:07 PM
cloudy's Avatar
cloudy
I hate nissan dealerships.. they are tryn to charge me $500 for replacing the fender liners and bottom engine/splash guard
Old Jul 18, 2005 | 10:19 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Ive had my CP on for 20K+ miles with no issues. My car idles way low at like 600rpm's and with the udp, my a/c doesnt blow cold at idle, as soon as I rev to 750-800rpm's its fine. If anything if your underdriving your a/c the condenser should last longer, not fail faster. Dont trust the tools at Jiffy Lube, go get a 2nd opinion from a good mechanic-also dont go to your stealership...
Old Jul 18, 2005 | 10:22 PM
sentry65's Avatar
sentry65
the burninator
can always raise your idle for better AC while still
Old Jul 18, 2005 | 11:10 PM
Nano's Avatar
Nano
Pulley, if installed correctly, shouldn't cause ANYTHING to fail
have had my pulley for 10K miles, and honestly couldn't tell the difference between before and after.. AC, PS, etc all have been working flawlessly. Even in traffic it has been working great.
Old Jul 19, 2005 | 05:49 AM
sentry65's Avatar
sentry65
the burninator
just curious, but if you install JUST the crank pulley, this would affect the AC even though the other pulleys are stock?
another question, how would the UR pulley fare with the hawker oddesey battery?
Old Jul 19, 2005 | 07:38 AM
SinCity350Z
Track Whore
This all backs up my origional thoughts, but I thought I would just check to make sure. Thanks.
Old Jul 19, 2005 | 08:04 AM
Nano's Avatar
Nano
Yeah, it would still affect AC
and I've been running a 680 hawker for a year without a single glitch. I wouldn't run the 535/545 though.
Fixxxercask
Nov 9, 2015 11:10 AM
EnjukuRacing
Sep 11, 2015 08:34 AM
EnjukuRacing
Sep 11, 2015 08:30 AM
