A/f Ratio guages and sensors
I am thinking about getting an A/F Guage And wondering if it can be tapped into the factory o2 sensorsor does it need its own o2 sensors, and if it needs its own sensors do i need to install a new or bung or replace the stock with this one?
Originally Posted by HankVQ
Not to jack you r thread or anything but I had a similar question. For the newer version of the VQ with wideband o2 sensors from the factory can you tap into them with a wideband gauge or do you still need another sensor and a bung welded in.
OK so 90% of the kits out there you need to weld on a new bung.
Could you replace the stock o2 with the supplied o2 and run it like that or is that bad?
NOt familliar with the o2 sensor and guages stuff.
Originally Posted by ZBoater
The guys at a local tuning shop wired a Defi a/f gauge to the stock sensor. It takes a while of driving for it to start working (like 2-3 minutes) - I guess its warming up. It will work, although some here question whether it is "worth" it or not. But to answer your specific question, yes, it can be tapped into the factory 02 sensor.
like mia says, narrowband is worthless on our cars. go wideband, and get a bung.
liqalu04
Jan 2, 2022 12:58 PM
