UR Crank pulley...Fuk it...
Old Aug 29, 2005 | 03:55 PM
  #41
joust75's Avatar
joust75
Originally Posted by Z1 Performance
actually older than you are...but no where near as lazy
Still too lazy to use caps and punctuation apparently.
Old Aug 29, 2005 | 03:59 PM
  #42
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Well, since I already graduated college, am not being graded here, and this is an internet forum, I did not see the need for the punctuation.
You are welcome for the link
Old Aug 29, 2005 | 05:19 PM
  #43
Juztin's Avatar
Juztin
bummer, i've put ~50k miles on my UR pulley set on the same old belt pair (gator, albeit the belts are cracked to high hell that i gotta replace soon). And I definately do not baby my car what-so-ever w/ no problems or noises at all from it. No squeaks ever, me and my bud just intalled it, but i took the whole front end apart to get direct access to the crank pulley as i didn't want to bother with a breaker bar. Plus the car has seen conditions as cold as -20 below and up to 108 here in Denver. But sounds like you've already tried plenty of options. I just used the gator recommended belt sizes as i originally purchased it as a combo (pulley set w/ belts). But hopefully you can get your issue resolved if you try swapping the pulley set. I'd say u should double check your pullies and make sure one of them aint wobbling ever so slightly or something.
Old Aug 29, 2005 | 07:22 PM
  #44
Rhoads's Avatar
Rhoads
I cross referenced the Gates belts on the Goodyear website and thought I would post them incase someone else wanted to try the Gatorbacks without getting a hard time looking for the part #. This is the belts for the combo of OEM Nissan accessory pulleys with UR crank puley
Part# Belt1= 4040355
Part# Belt2= 4060445
I had to order them from Advanced Auto and am expecting them Tuesday. Install will be Saturday. I'll post a follow-up on if it cleared up the noise from the pulley. The Gatorbacks are impressive looking belts. Very grippy
Old Aug 29, 2005 | 07:56 PM
  #45
joust75's Avatar
joust75
Yes, That is because you are LAZY!
Old Sep 1, 2005 | 09:33 AM
  #46
Rhoads's Avatar
Rhoads
Got anxious and installed them yesterday. Belts work great, no noise at startup, no ee-ee-ee noise at idle. If you have pulley noise definetly try these belts!!
lolwatbro
Oct 9, 2021 04:58 AM
B Esquire
Sep 24, 2015 07:52 AM
Shane86
Sep 17, 2015 05:33 PM
