ecu reflash ??
Old Aug 9, 2005 | 09:14 AM
goaway's Avatar
goaway
Default ecu reflash ??
i have an 03'z with injen cai and injen ses.i am in the process of installing alpha headers and resinated test pipes i am reading alot of threads about reflashing the ecu.is this nessary to do to keep the car runing properly or is the reflash just to get more power? with the mods i have is it necasary at all? i plan to stay NA,alot of threads say it is needed when the car has alot of NA mods which i don't consider my self to have but no one defines what that level is.will i see gains with the parts i am installing with out a reflash or do i need it? if needed what reflash is the best? ......thank you
Old Aug 9, 2005 | 10:36 AM
HKS350z's Avatar
HKS350z
Hey buddy, I currently have intake, headers, high flow cats, and an exhaust. After driving it for a few days, i noticed my exhaust tips being perfectly clean (car running WAAAAY too lean). After getting all the bolt ons, I wouldn't take ur car to high rpms because you're not running enough fuel. I would highly recommend getting a reflash either by AAM or Technosquare. I personally went with the AAM and have no regrets. Mike is very helpful and he's answered tons of my questions. Hope that helps.
Old Aug 9, 2005 | 11:15 AM
lafdclass002's Avatar
lafdclass002
I would recommend a ECU flash. I noticed a big difference in the way my car ran. Not so much in direct HP, but it ran much better/smoother (mods prior to flash: intake, plenum, headers & exhaust). Plus I liked having the rev limiter removed. I used Techno Square and would recommend them.
Old Aug 9, 2005 | 11:35 AM
thawk408's Avatar
thawk408
It is fine to take it to redline, nothing bad will happen. It might be running lean, but not anything that will screw up your engine.
Old Aug 9, 2005 | 01:10 PM
A_16's Avatar
A_16
will the reflashed ecu continue to help if you add more mods later? As in, right now its just a pop charger, if say I get the reflash, then added the rest of the exhaust on after, will it need to be redone or will the maps adjust accordingly?
Old Aug 9, 2005 | 01:29 PM
HKS350z's Avatar
HKS350z
The VQ motor is very strong and it would probably take a good beating before messing up but you definitely don't want to keep running lean at high rpms otherwise you might detonate which will cause engine failure.
Old Aug 10, 2005 | 10:04 AM
goaway's Avatar
goaway
thanks guys, if anyone else has any input it would also be appreciated. what is the difference between the flashes, does each one have pros and cons or are they basicy the same? i just want my car to run right with out having to worry about it breaking and also get some hp's. eventualy i want to do a full plenum upgrade when i get the $$ will i need to reflash agan if i decide to flash now? ....thank you for your input the more i get the easier it will make my decision
Old Aug 10, 2005 | 12:26 PM
isugoo's Avatar
isugoo
i have newbie question.
i would like to reflash ecu, where do i have to bring or how can i buy new ecu?
never done it. please help.
thanks in advance.
Old Aug 10, 2005 | 12:48 PM
HKS350z's Avatar
HKS350z
I would probably get all your n/a mods put on before getting the reflash. When you get the reflash, you will have to fill out a form with all your mods and they will reflash it accordingly.
Old Aug 17, 2005 | 05:16 PM
TunaRollZ's Avatar
TunaRollZ
I agree w/ HKS350z.
For me, my car on the dyno was proof that the VQ runs damn lean in the midrange w/ the common air flow mods... (i/e/tp/pl). Add headers and/or cams and you really shouldn't be smashing on it w/o some kind of fuel mods or engine management...unless you like detonating and bouncing off your knock sensor's safety net.
hulkout
Tuning
Sep 30, 2015 12:33 PM
speedsniper
Sep 14, 2015 08:46 AM
Twiztids4
Tuning
Sep 10, 2015 04:02 PM
