Reflash on the 300hp motor
Old Aug 9, 2005 | 12:48 PM
thawk408's Avatar
thawk408
Default Reflash on the 300hp motor
Has anyone gotten a reflash yet for the 300hp motor? If so, did you raise the revlimiter? I am thinking about getting one, but I am not sure if I should leave the stock 7k redline or raise it up to 7500. I think with the new cams and timing it might actually make power up that high. What does anyone think?
Old Aug 9, 2005 | 01:33 PM
Nano's Avatar
Nano
the old engine makes power way past it's 6200 rpm peak with a few bolt-ons. Some make power until close to 7000rpm with mild cams.
the new engine should make power well beyond 7000rpm with the bolt-ons you have.. but I doubt 7500rpm without cams.
Old Aug 9, 2005 | 01:53 PM
thawk408's Avatar
thawk408
I need to go dyno with the mods I have to see how my power looks close to redline. The last time I dynoed was with just the plenum and I had a flat HP line from around 6k up. Check it out:
http://community.webshots.com/myphot...ecurity=sJKGpr
Fixxxercask
Nov 9, 2015 11:10 AM
