Easy way through the drivers side Firewall?
Old Aug 14, 2005 | 12:49 PM
MMC Racing's Avatar
MMC Racing
Default Easy way through the drivers side Firewall?
I seen plenty of info on running through the passenger side firewall near the battery, but is there an easy path on the drivers side too?
-Mark
Old Aug 14, 2005 | 12:58 PM
g356gear's Avatar
g356gear
On top of the tranny through the shifter opening into the center console area.
Old Aug 14, 2005 | 01:21 PM
booger's Avatar
booger
you can use the E brake cable hole also
Old Aug 14, 2005 | 03:07 PM
MIAPLAYA's Avatar
MIAPLAYA
I just drilled a small hole on the firewall from the inside of the car. Also had another one drilled there for gauge install later...both fine..used plastic grommets on the holes to prevent from cutting the wires...
Old Aug 14, 2005 | 04:34 PM
zzzya's Avatar
zzzya
There is also a rubber grommet supporting a wire harness that goes into the brake fluid compartment. You can see the rubber grommet from inside the car if you look up over the gas/brake pedals.
Old Aug 14, 2005 | 09:18 PM
Tackett's Avatar
Tackett
That grommet you are talking about is where I run all my wires through.
Old Aug 15, 2005 | 06:52 AM
King Tut's Avatar
King Tut
Yep I have used that one as well.
Old Aug 15, 2005 | 07:51 AM
theking's Avatar
theking
Same here. Since this is a left or right hand drive car the firewalls are almost identical on each side. There is a nice size grommet that you can see better from inside the cabin.
Old Oct 25, 2005 | 05:47 PM
Cuore_alfa's Avatar
Cuore_alfa
humm, i have to take a look of this, i drill ten holes to my Z today....
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
kyin
Oct 15, 2015 05:54 AM
samansharif
Sep 25, 2015 12:31 PM
