Need some opinions
Old Aug 23, 2005 | 04:43 PM
KTaylor's Avatar
KTaylor
Default Need some opinions
Ok. I have a 03 350z with a built motor and a PE TT kit. right now i have the boost set at 5.5 (stock PSI is 6). But anyways my clutch is goin out because i still have the stock one. I know i need a new pretty badly but i was wondering what combo for a clutch and flywheel you all would reccomend. Also i plan on turning the boost up soon so i need them to be abe to handle alot of hp. So if your guys could let me know what the best one for the money is that would be awesome. Thanks, Kurt
Old Aug 23, 2005 | 05:32 PM
KTaylor's Avatar
KTaylor
anyone?
Old Aug 23, 2005 | 06:03 PM
SFZ's Avatar
SFZ
You could look into the JWT clutch/flywheel combo, it can handle more torque than the stock setup. From what I've read on here, the Tilton setup won't work for FI, so stay away from that one. Check out performance nissan, i'm sure they could point you in the right direction.
Old Aug 23, 2005 | 06:36 PM
Gman2004's Avatar
Gman2004
most guys with tt kits and built motors are going with the ats twin carbon clutch.
http://www.forgedinternals.com/store...cat=261&page=1
from forgedinternal's website
This is truely the ultimate clutch on the market. ATS has been making clutches for many years, but only recently began marketing their products in the USA. Becuase of their limited marketing budget, you dont hear about this brand as often as Exedy and some of the other brands out there. But the ATS twin carbon disc clutch will likely be the last clutch you ever buy. It is rated at 700ft/lbs of holding power, but has stock enagement and pedal pressure. The entire assembly weighs just under 26lbs, and includes a lightened flywheel and bearing. Becuase it use full floating pure carbon twin disc, these clutch doesnt chatter like other racing clutches, and with the carbon surface, the clutch actually grabs MORE as you heat it up, rather than overheating and slipping like a conventional clutch. We also offer a triple disc carbon clutch, and an option of a heavier flywheel. Email us for details on these items. They are good for well over 1100ft/lbs of holding power. An optional carbon heat treated flywheel and pressure plate is availble for an extra $100. EMAIL US about the single disc, triple disc, and heavier pressure plate options.
Old Aug 24, 2005 | 04:09 AM
gringott's Avatar
gringott
I have the pe kit and I am running a nismo clutch and flywheel - np, and very streetable.
Whiskers1996
Tuning
Aug 1, 2020 04:09 PM
wanderingstuden
Jan 28, 2016 07:03 PM
tm9293
North East Marketplace
13
Oct 17, 2015 09:14 PM
kyin
Oct 15, 2015 05:54 AM
samansharif
Sep 25, 2015 12:31 PM
