dry Edelbrock vs Nitrous Xpress wet nitrous system
Old Sep 7, 2005 | 10:22 PM
USMC-Z's Avatar
USMC-Z
Z Veteran
Default dry Edelbrock vs Nitrous Xpress wet nitrous system
More than hp, I am looking for engine safety. Which of these kits are safer for your engine? I know the nitrous xpress kit has different solenoids you can add to increase safety, but I have not seen any of these for edelbrock. Are theirs already integrated in the kit? Lastly, does nitrous xpress make a WOT sensor that activates the system once you are past a specified rpm? I think its a sensor hooked on the throttle body. Is this made for the Z?
Old Sep 7, 2005 | 10:40 PM
Rickdogg's Avatar
Rickdogg
Out of hiatus
I would suggest checking out the nitrous section of our forum, which is where I learned a lot about N20. Nitrous Express all the way as it is a wet system and they make a plethora of aftermarket parts that will coompliment the basic kit. Yes, they do have a progressive controller that controls when the N20 sprays based on RPM, WOT, and also shoots different HP in different gears!
https://my350z.com/forum/nitrous-oxide-181/
Old Sep 8, 2005 | 04:28 AM
derek_i's Avatar
derek_i
Unless you have changed your fuel system to a return system, the wet kits are the only way to go.
-D
Old Sep 8, 2005 | 04:37 AM
ZU L8R's Avatar
ZU L8R
Viper Sellout
Unless you have on of the Kinetix SSV manifolds you should do a wet kit.
Old Sep 8, 2005 | 06:57 AM
USMC-Z's Avatar
USMC-Z
Z Veteran
For anyone thats actually installed a wet nitrous kit, what is the difficulty level? I plan on buying a kit soon as a "project" on my car. I'll check into the nitrous forums now. Thanks.
sales@czp
Sep 23, 2019 03:30 PM
Justin100
Nov 29, 2015 03:58 PM
nanotech
Oct 2, 2015 05:02 AM
