Engine Temperature = Hot!!
Old Sep 18, 2005 | 02:32 AM
Tortuga's Avatar
Tortuga
Default Engine Temperature = Hot!!
So it is was hot here in Texas today, got up to 98/99F. I open up my hood and the heat from under was scary. Do all Z's run hot? The engine temp. gauge inside the car has always been same showing in normal range. I touch the upper plenum and I could cook an egg on there. Just curious. Thoughts?
Old Sep 18, 2005 | 03:52 AM
sigsauer87's Avatar
sigsauer87
Old Sep 18, 2005 | 06:08 AM
HarvesterUT's Avatar
HarvesterUT
yeah mine is hot as well......get cookin!
also i have heard that running lean (with several NA mods) your engine wil run a little hotter
Old Sep 18, 2005 | 06:40 AM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
The Motordyne Iso Thermal upgrade will fix the scalding plenum temperatures real quick.
Old Sep 18, 2005 | 07:42 AM
The 350Z runs hot. Yes. When the ambient temperature is 60 degrees, take a ride with the windows open. Put you hand on the side of the transmission hump: its warm. Stop the car, open the drivers door, put your hand down and touch ground. You can feel the heat from under the car. If you're comfortable at 70 degrees, close the windows and vents: the interior will soon reach 70 degrees.
Nissan shorted the Z on insulation (none on the underside of the hood) for weight reasons.
Old Sep 19, 2005 | 08:55 AM
redlinez33's Avatar
redlinez33
I have been pretty concerned about my engine bay getting that hot so iam about to get a luvered hood. That cant be good for all the wires and etc..
Old Sep 19, 2005 | 09:04 AM
thawk408's Avatar
thawk408
Would using Redline fluid in the tranny help with some heat?
Old Sep 19, 2005 | 09:30 AM
lunartick13's Avatar
lunartick13
Just curious, has anyone tried removing the thermostat completly? this would allow coolant to flow without restrictions. Naturaly this is only for Summer operation..What about you people that live in places like Arizona (lived there for a year 10 years back) where it really gets hot, how are you guys dealing with this??
liqalu04
Jan 2, 2022 12:58 PM
Fixxxercask
Nov 9, 2015 11:10 AM
SharX59
Sep 30, 2015 10:54 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
