Compression, wet-down test results
Old Sep 22, 2005 | 05:15 PM
Z BOY's Avatar
Z BOY
Default Compression, wet-down test results
i have 1400 mi on my new longblock provided under warranty due to oil consumption problem. i'm going fi soon, so i took my z in for these tests. dealer said everything is fine, but i want you guys to interpret the numbers for me:
dry: 1-185 psi, 2-180, 3-180, 4-185, 5-180, 6-180
wet: 1-205, 2-205, 3-200, 4-200, 5-200, 6-205
btw, on my first engine, i followed the breakin schedule to the letter. this time, i used the heat cycle method and went to redline each time.
Old Sep 22, 2005 | 05:47 PM
g356gear's Avatar
g356gear
Numbers look dead on perfect for the stock compression of the motor. Dry test is a regular compression test. Wet test is if they put a little oil in the cylinder to seal the rings....gives higher numbers.
Old Sep 22, 2005 | 09:20 PM
Z BOY's Avatar
Z BOY
really? cool! so much for the factory breakin schedule.
Old Sep 23, 2005 | 12:10 AM
kosmic's Avatar
kosmic
Is the heat cycle method the same as the "secret" moto-man (or something like that) break in method that's been discussed in the past to load and seal the rings?
Old Sep 23, 2005 | 04:14 AM
Z BOY's Avatar
Z BOY
don't know about secret. its something i think raceboy posted on the topic of breakin long ago. heat the engine up with gradually more vigorous drives, then let it cool down completely after each drive.
Old Sep 23, 2005 | 05:30 AM
Jaki's Avatar
Jaki
Compression test looks good.
Old Sep 23, 2005 | 10:12 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Perfect if you ask me. Mine compression testing at 190-192 between all cylinders....warm motor, dry. Anything between 180-195psi is excellent, as long as there are not major variances between the cylinders.
Old Sep 23, 2005 | 10:35 AM
gatti-man's Avatar
gatti-man
yes it is the moto-man theory but it isnt his theory alone. Most people who want max hp out of their engines go by this method.
Old Sep 23, 2005 | 06:27 PM
overZealous1's Avatar
overZealous1
nissan figures for this test is 185-140psi. so looks like your golden!!
Old Sep 23, 2005 | 06:31 PM
Z BOY's Avatar
Z BOY
awesome. thanx!
issyz
Jul 2, 2017 03:04 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
