DIY Pulleys?
Old Sep 24, 2005 | 12:02 AM
VeilsideZ33's Avatar
VeilsideZ33
Default DIY Pulleys?
Just wondering if anyone has done it themselves and how extensive the work was?
thansk~
-ilon.
Old Sep 24, 2005 | 12:15 AM
Triple8Sol's Avatar
Triple8Sol
Installed a UR UDP on my Maxima. Took some time, but wasn't that bad. The Z/G should be pretty similar as well. You can do it, just be careful when loosening the tensioner bolts...
Old Sep 24, 2005 | 02:30 AM
Z BOY's Avatar
Z BOY
need someone else to press brake pedal. make sure you apply correct torque.
Old Sep 24, 2005 | 04:46 AM
DavesZ#3's Avatar
DavesZ#3
I recently installed the KJR lightweight pulley. The install is pretty straight-forward but it helps to have somebody else with you to step on the brake pedal when you're trying to break the bolt loose.
You can download a copy of their installation instructions from the website:
http://www.kjrperformance.com/products.htm
That will give you an idea of what to expect.
Old Sep 24, 2005 | 09:25 AM
VeilsideZ33
thanks guys //
does anybody know how much it is approximately to have a shop do it?
Old Sep 24, 2005 | 09:27 AM
DavesZ#3's Avatar
DavesZ#3
Shouldn't take more than 1 hr of labor so figure it based on your local rate.
Old Sep 24, 2005 | 09:29 AM
myehrick09's Avatar
myehrick09
The shop here in Jackson charged me $100 for labor.
Old Sep 27, 2005 | 04:07 AM
Z BOY's Avatar
Z BOY
36ftlb+60' or 90ftlb torque
Old Sep 27, 2005 | 07:02 AM
VeilsideZ33
my local shop is saying 3 hrs... WTF
Fixxxercask
Nov 9, 2015 11:10 AM
NissanZcrazy
Sep 23, 2015 07:59 AM
Calinismo350z
Sep 14, 2015 04:04 PM
EnjukuRacing
Sep 11, 2015 08:34 AM
EnjukuRacing
Sep 11, 2015 08:30 AM
