need advice on best lsd oil and friction modifier
Old Oct 10, 2005 | 02:49 PM
gatti-man's Avatar
gatti-man
Default need advice on best lsd oil and friction modifier
I ended up buying the nismo lsd since im not so worried about noise as my car is already noisy. My main q is what is the best oil and friction modifier to run with my nismo lsd also the best MT oil since im probably swapping that out too to a synthetic. Thanks in advance.
Old Oct 24, 2005 | 01:34 PM
daveh's Avatar
daveh
I can shed some light on this since I have now tried a couple different things. My lsd was never very loud, but recently it was getting louder and engaging abruptly. The noise itself doesn't bother me but the way the diff acts more abruptly when it is noisy is not desirable to me.
After the initial break in (and dizzyness from 20 minutes of figure 8's), I started using Redline 75w90 and has been ok, however after about 4 track days, the diff seems to get a little chattery. I was looking for some royal purple this weekend but my local shop was out of it so I gave mobil 1 a try since it was readily available. It was horrible. Aside from the obvious popping, the engagement was way too abrupt and the car was skipping around corners as the wheels were locking up. I immediately went to autozone and got a tube of sta-lub friction modifier. I put half a tube in and viola. The diff now acts better than it ever did. I am very shocked at what a difference oil can make in these units.
I'm not sure yet how long the mobile 1 with additive will last before it gets noisy, but so far the engagement is the best I've felt. Anyone who is complaining about the noise should really try some additive.
Old Oct 24, 2005 | 01:54 PM
gatti-man's Avatar
gatti-man
i am going with the redline since it has friction modifier in it already. If that doesnt do it i will switch to amsoil that has a seperate friction modifier additive.
Old Oct 24, 2005 | 02:01 PM
daveh's Avatar
daveh
Redline comes with 5% slip modifier. They also sell extra modifier. The redline tech told me that I could try 6% modifier (.5 to 1 oz) to quiet things down but to be careful not to add too much. The idea is to get just enough to reduce the chatter. Anything more would reduce the effect of the lsd. If the mobile 1 doesn't last I may go back to redline and add a little extra modifier.
The mobile 1 is not as thick pouring as the redline. Not sure if that means anything.
Old Nov 8, 2005 | 11:01 AM
daveh's Avatar
daveh
Another update, the mobile1 only lasted about 2 track sessions before getting very noisy. I got some royal purple to put in the next morning before going back out on track and the car was back to normal. It seems like the mobile1 doesn't hold up to the heat. It drained out like water.
The royal purple is thick like the redline (and actually is purple). It seems to be ok, perhaps a little more chatter than the redline at the end of the day.
I'll probably go back to redline at my next change with a 1/4 bottle of modifier, now that I've satisfied my curiosity of other products.
Old Nov 8, 2005 | 11:28 AM
chimmike's Avatar
chimmike
I'm sure many of you have used MT90, but has anyone tried the redline heavy shockproof in both the tranny and the diff?
The stuff is thick like honey, but when heated, makes for EXCELLENT gear oil........I've used it in two other cars as tranny fluid, and it goes from nice shifting (MT90) to shifting like butta. It's thick enough I think it'd be a great diff oil as well.
Old Nov 8, 2005 | 05:23 PM
racin's Avatar
racin
Nissan Motorsports favors Royal Purple from their findings with the LSD.
Old Nov 8, 2005 | 05:37 PM
MIAPLAYA's Avatar
MIAPLAYA
Werd...I sent an email to Nissan Motorsports when I got my diff and they said to use Royal Purple 80W-90 after break in. That being said I have been using Redline 75W-90 for a while now and it works great. But I may try some Amsoil 80W-90 or Royal Purple next.
Old May 13, 2006 | 12:33 AM
mistaboosta's Avatar
mistaboosta
what kind of lubricant do you use for break in ?
Old May 13, 2006 | 12:28 PM
New2350's Avatar
New2350
bumpn
Old May 14, 2006 | 04:45 AM
mistaboosta
hiho
Old May 14, 2006 | 06:24 AM
n8vz's Avatar
n8vz
Royal Purple Max-Gear comes in 80W-90? I use Max-Gear 75W-90 and it works great.
Old Sep 6, 2006 | 09:07 AM
2005ssm's Avatar
2005ssm
Default how about Mobilube HD LS 80w-90?
I googled "80w-90" and came across Mobil's website, specifically linking to a page about Mobilube HD LS 80w-90 Limited Slip Gear Lubricant. It is GL5 and is supposedly designed for high performance demands on the drivetrain; higher speeds, higher torque, heavier loads and limited slip capabilities.
Just thought I'd throw it out there as I believe it may be different than the other Mobil products referenced thus far...
Terry
Old Sep 6, 2006 | 01:15 PM
Zmego1985's Avatar
Zmego1985
I use amsoil with the slip lock additve.
Old Sep 6, 2006 | 03:01 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
You guys need to try Motul 90PA, specifically designed for clutch style LSD's. Very very quite operation. 2L bottle is about $17
http://www.forgedperformance.com/sto...cat=278&page=1
Old Sep 6, 2006 | 03:16 PM
Quijano187's Avatar
Quijano187
i need to change mine oil, does it matter if you have the stock diff?
Old Sep 6, 2006 | 03:21 PM
Mike Wazowski's Avatar
Mike Wazowski
werd, I use it too. awesome stuff.
Old Sep 6, 2006 | 03:32 PM
Sharif@Forged
Forged Performance
For a gear driven or stock diff, we use this: http://www.forgedperformance.com/sto...cat=278&page=1
Old Sep 6, 2006 | 03:35 PM
techcontrol's Avatar
techcontrol
With the VLSD do you use any additives with the Motul gear lube?
Old Sep 6, 2006 | 04:29 PM
Sharif@Forged
Forged Performance
We do not use additional additives.
