Top speed for each gear (6mt)
Old Oct 11, 2005 | 05:32 PM
Gman2004's Avatar
Gman2004
Default Top speed for each gear (6mt)
Other than going through your gears while gunning it, how do you calculate the top speed for each gear.
Old Oct 11, 2005 | 05:52 PM
002-M-P's Avatar
002-M-P
it all depends on what size wheels and tires you are running...there are calculator around on the internet where you input each gear ratio, your final drive ratio, and tire size and it will spit out the speeds of each gear. I will look to see if I can find what I'm talking about.
Old Oct 11, 2005 | 05:56 PM
002-M-P's Avatar
002-M-P
Here is one calculator (have to calculate each gear indiv. though)
http://www.bimmerzone.com/speed.htm
Old Oct 12, 2005 | 04:21 AM
Gman2004's Avatar
Gman2004
ok thanks. two more questions though. how do you find out the gear ratio for each gear? and what is the final drive for the 6mt....I pretty sure it is 3.5, I think.
Old Oct 12, 2005 | 04:30 AM
002-M-P's Avatar
002-M-P
Here you go...for both the 6MT and 5AT Guys
6-Speed Manual
1st: 3.794
2nd: 2.324
3rd: 1.624
4th: 1.271
5th: 1.000
6th: 0.794
Reverse: 3.446
Final Drive: 3.538
5-Speed Automatic
1st: 3.540
2nd: 2.264
3rd: 1.472
4th: 1.000
5th: 0.834
Reverse: 2.370
Final Drive: 3.357
Old Oct 12, 2005 | 06:29 AM
Gman2004's Avatar
Gman2004
Thanks again.
Old Oct 12, 2005 | 07:01 AM
002-M-P's Avatar
002-M-P
Originally Posted by Gman2004
Thanks again.
Anytime...
Old Oct 12, 2005 | 10:04 AM
Rickdogg's Avatar
Rickdogg
Out of hiatus
Better:
Miraclekidjr's Avatar
Miraclekidjr
So it says I can hit 200.5 MPH with my wheels if I get the reflash......SWEET
Old Oct 12, 2005 | 10:06 AM
Rickdogg's Avatar
Rickdogg
Out of hiatus
It could be just wheel speed without any real life variables
Old Oct 12, 2005 | 11:24 AM
002-M-P's Avatar
002-M-P
Originally Posted by Rickdogg
Better:
Nice chart, but remember thats only good if you use the stock tire diameter.
350Z_Al
Oct 29, 2020 07:44 PM
sherm
Apr 11, 2020 05:21 PM
Stevo Z
Oct 3, 2015 09:14 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
