Reflash ECU
Old Oct 17, 2005 | 10:23 AM
Nismo 350z's Avatar
Nismo 350z
Default Reflash ECU
Hey guys. I was going to reflash my stock ECU from TS soon but I was gonna ask for those of who have done it... is it worth it? I have all my mods done in my sig and is the reflash necessary? And how does it feel taking the car up to 7100rpm and does it void the warranty of the car? Would the reflash make my mods work better or what? I heard that someone in the forums that some people reflashed and got really poor AFR's... like 15 while others get perfect ones like 13.1( I think alberto). I plan on staying NA and I would appreciate all your opinions on this. Thanks.
Old Oct 17, 2005 | 10:26 AM
Rickdogg's Avatar
Rickdogg
Out of hiatus
I would recommend it with the items you have on your car. You will definitely have an advantage being in SO cal since you can just drive it in and tune it if you have a wideband
Old Oct 17, 2005 | 11:25 AM
kamz's Avatar
kamz
I'm planning on getting a reflash as well. Can we set up a group thing? I know they have a 10% discount for Halloween but that's too early for me. November would be a better month, money wise...
Old Oct 17, 2005 | 12:16 PM
Nano's Avatar
Nano
I didn't know they had 10% discount for halloween!
is it good on the L-spec flash as well?
Old Oct 17, 2005 | 12:22 PM
kamz's Avatar
kamz
Actually it may be for the locals only cuz the contingency is that we shop up dressed up for halloween...
https://my350z.com/forum/southern-california/147306-technosquare-halloween-special-1-day-only.html
Old Oct 17, 2005 | 12:47 PM
Chebosto's Avatar
Chebosto
im trying to get them to do an Xmas special.. (i.e. bring in a toy for Toys for Tots)
until then. the halloween appointment is legit...
its good for all their flashes.
Old Oct 17, 2005 | 01:39 PM
Nismo 350z's Avatar
Nismo 350z
Rickdogg what if I dont have a wideband? And how does it feel when you pass 6600rpm?
Old Oct 18, 2005 | 04:27 AM
EM-EFER's Avatar
EM-EFER
Yes the reflash could void your warranty. The only way they will see the reflash if they hook it up to there computer. I have a stock ECU handy just in case from a wrecked Z.
Old Oct 18, 2005 | 05:48 AM
jpc350z's Avatar
jpc350z
Don't think you can just swap ECU's and expect the car to run.. For one the immobilizer is programmed into each ECU..
Old Oct 18, 2005 | 09:29 AM
Rickdogg's Avatar
Rickdogg
Out of hiatus
The car's sweet spot with stock cams is still peaked at 6600 IMO and the extra 600 rpm is good for road racing when you just need to stay in "that gear" just a bit longer so you don't have to slow down by upshifting. With a nice set of cams, this can be a different story
Old Oct 18, 2005 | 09:31 AM
Nismo 350z's Avatar
Nismo 350z
I see. Thanx alot guys.
Old Oct 23, 2005 | 01:16 AM
GAaaAR's Avatar
GAaaAR
What kind of TS Reflash is recommended?? Because i have similiar bolt ons to what nismo 350z has and i also want to get a TS reflash. I was wondering if i should get just the regular one, since i just have simple bolt ons, or is it worth it to customize my reflash? Im tryin to avoid dynoing my car, but if it really helps that much, ill do it. What do u guys think? Thank You.
Old Oct 23, 2005 | 04:52 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
GAaaAR - I would recommend you visist Altered Atmosphere and have it flashed on your car, rather than trying to do it via mailorder - you will be much happier. Though it all depends on your mods
Old Oct 23, 2005 | 01:37 PM
Rickdogg's Avatar
Rickdogg
Out of hiatus
Exactly. What I would suggest is tuning it in person at AAM, or if you go through TS, dyno the car first and mail that along with your ECU.
Old Oct 23, 2005 | 03:15 PM
EM-EFER's Avatar
EM-EFER
Your right. But, not when you have a valet key cut & programmed for your ignition and for the other ecu.
Old Oct 23, 2005 | 04:24 PM
SnakeBitten's Avatar
SnakeBitten
Huh...Excuse my ignorance...Please explain.
Old Oct 23, 2005 | 06:41 PM
EM-EFER's Avatar
EM-EFER
Each key is specific to the ECU for your car. If the chip in your key doesnt match the ecu your car won't start... the dealer can program any nissan key to match the ecu allowing you to use a different one.
Old Oct 24, 2005 | 08:01 AM
GAaaAR's Avatar
GAaaAR
Is AAM Reflash as good as TS?? I kno TS Reflash is proabably the most popular reflash but does AAM REflash offer everything a TS Reflash would offer and more??
Old Oct 24, 2005 | 09:30 AM
SnakeBitten
Do need the ecu hooked up to the car for them to do that? Or can I just get an ecu from say a junk yard and just ask Nissan dealer to match a key to it?
Old Oct 24, 2005 | 09:51 AM
Rickdogg's Avatar
Rickdogg
Out of hiatus
AAM uses TS software. Same thing, but the advantage that you East Coasters have is that there is a dyno on site at AAM to my knowledge.
