help! "KJR" light weight pulley...install... cant get stock one off??
Old Oct 19, 2005 | 02:10 AM
zmespeed's Avatar
zmespeed
Exclamation help! "KJR" light weight pulley...install... cant get stock one off??
ok so ive pulled the fan and got the belts off but i cant get the thing off. my buddy has some air tools but i cant get the stronger one in there. and even when i try to use a long handled tourqe rench i cant get it. he has a wheel puller to pull it off but i need to get the bolt off... pleas help me....getter done. ......got no time to look sorry if the answer is al ready out there. btw i dont like the using the engine starter methiod.
Old Oct 19, 2005 | 02:46 AM
neffster's Avatar
neffster
You need to go buy some penetrating oil. Apply it several times over the course of a few hours and let it work its way into the threads. Eventually the air tools and the penetrating oil will help you get this nasty bolt off.
Old Oct 19, 2005 | 04:22 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Ive done 2 crank pulley installs you dont need to pull th efan. Just get a large 1/2" breaker bar with a metal pipe over it. Put it on the crank pulley bolt, and set the bar/pole on the ground at the 5 o'clock position. Now simply turn the motor a few times. The torque from the starter will loosen the bolt. SImple as that. Dont break a sweat and it works every time. Good luck.
Old Oct 19, 2005 | 12:47 PM
350zWarz's Avatar
350zWarz
i did it that way too except i just had my brother hold the brake pedal down instead of starting the engine....the car was rolling back and forth when i tried to loosen in gear without the brakes applied
Old Oct 19, 2005 | 01:31 PM
teh215's Avatar
teh215
How did you keep the car from starting?
When I installed one I just use the pipe w/breaker bar method. No need to remove fans, etc....
Old Oct 19, 2005 | 02:11 PM
Nismo 350z's Avatar
Nismo 350z
Whats the difference between the KJR and the UR one?
Old Oct 19, 2005 | 02:12 PM
teh215's Avatar
teh215
KJR is not an underdrive pulley. It is the smae diameter as OEM.
Old Oct 20, 2005 | 08:48 AM
Alberto's Avatar
Alberto
Cranky FI Owner
You dont turn the key for 2 seconds till it starts just a quick turn of the starter. Just turn the key till you hear the motor start to turn and pull back on the ignition. You only have to barely turn the crank 2X and it will break free. Painless and easy as hell, everybody should do it that way.
Old Oct 20, 2005 | 09:12 AM
Eldy's Avatar
Eldy
There's also a "pulley removal wrench" from harbor freight. It's basically a strap wrench but the strap included with it is a v belt so it grabs the pulley better.
It's referenced here in the fifth post: http://www.4x4wire.com/forums/showfl...47&Main=755206
I haven't used it, but for $9 +tax it should be worth a try.
Old Oct 22, 2005 | 01:26 AM
zzzya's Avatar
zzzya
5AT OR 6MT? Huge difference if you don't do the engine starting method.
Old Oct 22, 2005 | 02:38 AM
TheMinel's Avatar
TheMinel
we tried with bars, wrenches, penetrating everything, brakes, in all gears etc. would not move.
Went to a proper shop, mechanic had the same problems. He in the end wanted to take off the radiator.... a full day's work.... I sold the pulleys. Not worth it, in my case
Old Oct 22, 2005 | 04:49 AM
Pats300zx's Avatar
Pats300zx
ECZA-President
I also had some difficulties with the shop that was trying to install my UD pulley. The bolt was on there so tight and it wouldn't budge. They used a huge breaker bar and were afraid of damaging the flywheel since its a manual.
I am taking it back and they are going to try and use a chain wrench on the pulley to get it off. I didn't want them to go through the headaches of pulling out the radiator to use air tools.
If the chain wrench doesn't work I will probably bag the pulley.
Old Oct 22, 2005 | 07:32 AM
Alberto's Avatar
Alberto
Cranky FI Owner
USE MY METHOD ITWORKS EVERY TIME ! You dont need to go to a mechanic to have this done its 2 tensioners you have to loosen and then retighten, and one crank pulley bolt you only need to tighten, cuz using my method it loosens itself, c'mon guys.....
Old Oct 22, 2005 | 09:38 AM
bio911's Avatar
bio911
i hope i won't have any problems with my install... but if i can remove a honda crank pulley which is tq close to 200lbs i think i should be able to do this one...
Old Oct 24, 2005 | 05:31 PM
zmespeed's Avatar
zmespeed
i tried every method listed obove. some of out cars have a stubern *** bolt simple as that i put so much force on that thing im suprisied it didnt strip.
Old Oct 24, 2005 | 07:01 PM
booger's Avatar
booger
Has any one take the light wieght pulley off since install ? Shop took mine off and it had a groove dug into it where it slips in the , or over the shaft .
Old Oct 24, 2005 | 07:38 PM
zmespeed's Avatar
zmespeed
i think that groove was there when it was new cause mine has a notch in it as well
Old Oct 25, 2005 | 06:17 AM
HarvesterUT's Avatar
HarvesterUT
are you talking about the little square notch on the inside of the inner circle? that is there from factory
Old Oct 25, 2005 | 07:40 AM
booger's Avatar
booger
No...There is a seal on the outer edge on the hole ,on the block and you slide in the pulley into it . It has dug a groove on the pulley , on the round part that slides into the block . I think Im going to put back on the stock pulley
Old Oct 27, 2005 | 11:23 AM
bio911's Avatar
bio911
why did u take it off?
