View Poll Results: CAMS
Jim Wolf
30
34.48%
Nismo
25
28.74%
Tomei
32
36.78%
Voters: 87. You may not vote on this poll
Cams
Old Oct 23, 2005 | 08:53 AM
350ZLO's Avatar
350ZLO
Default Cams
I building the car all motor and was wondering what cams everyone recommends. it is a daily driver but i take it to the auto cross track and very rarely to the drag strip. i know the Z isnt a drag car thats why i auto cross more than drag race. just wondering what cams all of you say would be best and what degree of duration. thanks
Old Oct 23, 2005 | 09:37 AM
Machupo's Avatar
Machupo
if you're staying N/A (as you say "all motor", i'm guessing here)... then it's a no-brainer... tomei 268's.
One thing... you say that you AutoX... you know that swapping cams will move you into the SM2 class, right? their pax score is brutal... don't expect to place anymore unless you're unreal behind the wheel.
Old Oct 23, 2005 | 09:40 AM
350ZLO's Avatar
350ZLO
i dont really do serious comeptition auto just go out with my friends once and a while.....id say i do really well now and i guess ill see how the difficulty rises in the SM2 class
Old Oct 23, 2005 | 12:32 PM
D350Z10's Avatar
D350Z10
Crawford is coming out with some pretty massive cams... You should wait and get those!
Old Oct 23, 2005 | 01:36 PM
zzzya's Avatar
zzzya
The nismo cams will work best with the stock ECU mapping. The JWTs will work the next best and then from there you will want a way to tune the car to maximize gains after going with cams. The Tomei cams are aggressive and require a more involved install and tuning, but will yield good upper rpm increases. I would think in autox you would be looking more towards the Nismo or JWTs to help keep a better power balance from lower rpms to higher rpms.
Old Oct 23, 2005 | 05:56 PM
350ZLO's Avatar
350ZLO
im gonna get the UTEC to tune the car along with when i get the cams.....so u think it would be good to get the tomei's with a good tune or will the nismo's or JWT still be better on autox
Old Oct 23, 2005 | 06:37 PM
Machupo's Avatar
Machupo
it depends on how you drive -- i spend most of my time at 5k and up (but then, i like the big track more than the autoX ) -- if you spend most of your time in midrange then it would actually be a tough call, because the tomei's have a dual-hump torque curve (without tuning, of course) with a peak at 3500 and another at 6k...
if you don't plan on hitting a large track hard or street racing, i'd change my reccomendation to the JWT's just because you won't need the bigger cams ('cause you wont be at 5k and up for most of the time )
Old Oct 23, 2005 | 06:44 PM
350ZLO's Avatar
350ZLO
well i do street race a little so from what your saying for that situation (street racing and autox) go with the tomei's?
Old Oct 23, 2005 | 07:36 PM
Nano's Avatar
Nano
I thought JWT cams = Nismo cams
Old Oct 23, 2005 | 07:54 PM
Rickdogg's Avatar
Rickdogg
Out of hiatus
I would vote for the tomei's if you track. That is my #1 choice so far when I go with cams.
Old Oct 23, 2005 | 07:59 PM
BlackoutZ's Avatar
BlackoutZ
Do the Tomeis have a lope to them?? I love that sound.
Old Oct 24, 2005 | 03:22 AM
Machupo's Avatar
Machupo
yup -- i've got my idle set at 1000rpm and i still get a pretty *****in' lope
Old Oct 24, 2005 | 10:19 AM
Nismo 350z's Avatar
Nismo 350z
Are any cams CARB legal or pass emmissions?
Old Oct 24, 2005 | 12:11 PM
rednezz's Avatar
rednezz
Machupo, did you get your car ECU tuned for the Tomei's or are you just running untuned with a raised idle? Also do you have a dyno sheet of the Tomei's that you don't mind sharing? I do alot of high speed track events so I would love to see you power curve to see if those cams would be right for me.
Old Oct 24, 2005 | 01:02 PM
RA11325's Avatar
RA11325
The JWT's are a bit more aggressive than the nismos offering mainly an upper rev-range power increase, where the nismos have all around power.
Old Oct 24, 2005 | 02:52 PM
Machupo's Avatar
Machupo
i'm running a stock tune with a raised idle (along with the technosquare F-spec flash)... the top hp was only about 245 (i have the dyno sheet in the car, which is at the body shop) -- mainly because i have a lower compression ratio, stock plenum/headers, no tune (oh, and the engine was brand new )... that's all in prep for the TT system that will go on shortly, then a retune to a nice level
as for the power curve with the tomei's it's pretty awesome (running rather lean at the top end though, so i'm looking forward to a tune!) -- hopefully i'll get the car back and get the intake straightened out down at crawford... i'll see if i can re-dyno it at the same time and get back to you!
Old Oct 24, 2005 | 02:55 PM
350ZLO's Avatar
350ZLO
i think im gonna go with the Tomei's with a UTEC and tune...you think thats a good idea
Old Oct 24, 2005 | 03:58 PM
nuff's Avatar
nuff
Nismo spec 2 are the only way to go in my opinion. You'll also need to get VTC modules with them so you don't loose your low end torque. The UTEC can't control them at the moment, but aparently they will add an option later on.
Old Oct 24, 2005 | 06:12 PM
plumpzz's Avatar
plumpzz
Have they released an idle control module for post 2004.5 models yet?
Old Oct 24, 2005 | 06:32 PM
Resolute's Avatar
Resolute
My understanding is yes, JWT makes the NISMO cams, at least the spec 1's or whatever the entry level cam is called.
Will
