Resetting the ECU??
Old Nov 23, 2005 | 01:35 PM
bobS's Avatar
bobS
Default Resetting the ECU??
I never reset my ecu after installing my jwt popcharger, high flow cats, and exhaust. IS it necessary? I did a search but couldn't find any solid answers.
Old Nov 23, 2005 | 02:20 PM
DavesZ#3's Avatar
DavesZ#3
Some people think it is necessary, others say it does nothing. It probably wouldn't hurt if you did do it.
Old Nov 24, 2005 | 03:29 PM
bobS's Avatar
bobS
Ya i think ill do it, not to much effort and why not.
Old Nov 24, 2005 | 03:37 PM
Ztalker's Avatar
Ztalker
if i'm not mistaken, the ECU would reset by itself in a few days of normal driving..... i could be wrong.... i read it somewhere in this forum that it may be neccessary to disconnect the battery first before installing a Popcharger to avoid stalling at high RPM in neutral.
Old Nov 24, 2005 | 04:49 PM
JERZ33's Avatar
JERZ33
http://www.technosquareinc.com/350reset.htm
Old Nov 24, 2005 | 05:22 PM
DavesZ#3's Avatar
DavesZ#3
The ECU doesn't reset itself - supposedly it relearns and makes adjustments based on the mods over a period of time. Resetting supposedly make it learn quicker since it's starting from the baseline.
There have been reports of highspeed stalling with the popcharger but I don't recall reading that disconnecting the battery will help prevent that. In general, it's always a good idea to disconnect the battery when working on the car.
Old Nov 24, 2005 | 05:39 PM
JERZ33's Avatar
JERZ33
DavesZ you are correct. An ECU will never reset itself. The ECU will lean and adjust as different signals are received. Resetting the ECU wont just magically happen, less electrical failure within the ECU or loss of power for more than five minutes.
To reset the ECU:
Originally Posted by Techno Square
ECU Resetting Procedures
Timing is extremely critical. If it is NOT DONE within the specify time, the ECU will not reset and the Check Engine Light (CEL) will continue to remain ON.
A stop watch or an analog clock with a second’s needle will be useful.
Operations Procedures
1. Confirm that accelerator pedal is fully released, turn ignition switch “ON” and wait 3 seconds.
2. Repeat the following steps (2a and 2b) procedures quickly five times within 5 seconds.
2a. Fully depress the accelerator pedal (HARD).
2b. Fully release the accelerator pedal.
3. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 10 seconds until the CEL starts blinking.
4. Fully release the accelerator pedal (while the CEL is still blinking)
5. Wait about 10 second.
6. Fully depress the accelerator pedal and keep it for more than 10 seconds.
7. Fully release the accelerator pedal (The CEL light will continue to blink).
8. Turn ignition switch to “OFF” position and now you can start the car. The CEL light should be gone.
If the CEL light continues to remain ON, repeat the above steps. Timing is EXTREMELY critical to resetting the ECU.
Old Nov 25, 2005 | 09:57 AM
bobS's Avatar
bobS
I never had a CEL light come on.
Old Nov 25, 2005 | 10:39 AM
DavesZ#3's Avatar
DavesZ#3
That's okay if you don't have a CEL (you certainly don't want one), clearing the CEL light is just a side effect of the ECU reset procedure.
Old Nov 25, 2005 | 11:27 AM
03track's Avatar
03track
Originally Posted by JERZ33
To reset the ECU:
thats alot of counting
Old Nov 25, 2005 | 02:00 PM
JERZ33's Avatar
JERZ33
Yea really... why not just make a damn button...
Old Nov 25, 2005 | 02:13 PM
bobS's Avatar
bobS
Ok i'm going to try this tomorrow after i wash my car, hopefully i don't mess it up lol
Old Nov 25, 2005 | 04:12 PM
DavesZ#3's Avatar
DavesZ#3
Leave the battery disconnected overnight, it has the same effect (resetting the ECU) and is a lot easier and foolproof.
Old Nov 25, 2005 | 04:14 PM
JERZ33's Avatar
JERZ33
If you wanna reset your radio, clock, sound setup(bass/treb/fad/bal) and the likes...
Old Nov 25, 2005 | 06:48 PM
No. The ECU will attempt to maintain parameters (emissions for example) regardless of what modifications you make. You can attempt to fool the ECU with an overnight battery disconnect or manual reset, but as soon as you begin driving the car, the ECU will attempt to return to “normal.” The only way to alter the ECU to take full advantage of your modifications is programming.
Old Nov 25, 2005 | 07:00 PM
JERZ33's Avatar
JERZ33
^ 1289723465234% correct.....
our ECM is programmed to do its job and it wont do other wise unless programmed to do so...
Remember the Terminator... kind of like that, but with less firepower and more just sit there....
Old Nov 27, 2005 | 11:50 AM
Cannysage's Avatar
Cannysage
you can disconnect the battery for 24 hours..
it took me close to 300 miles for my ecu to adjust to my popcharger, without resetting. computer should learn by itself, but with multiple mods, it may take longer. you should 'reflash' after all them breathing mods.
Old Nov 27, 2005 | 02:20 PM
JERZ33's Avatar
JERZ33
Or get a stand alone, a book and some time....
I really wanna learn to tune my VQ... cant see spending all that $$$ having someone else do it...
Old Nov 27, 2005 | 05:42 PM
bobS's Avatar
bobS
So my "gains" from the butt dyno will go away? Like the car feels quicker, is the ecm going to adjust over time and the gains will decrease, i should have done a before and after dyno but i know it did something, the car def. feels quicker. I plan on getting a vorteq this summer so i don't want to go crazy reprogramming just yet. the intake is just temporary
Old Nov 27, 2005 | 06:00 PM
JERZ33's Avatar
JERZ33
Remeber Bob.... speed can me mental as well. When I had my Scion, after I put my intake, headers, exhuast and, coil conversion kit, I thought that thing was a batt outta hell. But the score board still said 17 seconds of defeat and pitty.
Then I got the Z... and I am mental. Mental with love
