Fluids?
Old Nov 25, 2005 | 05:07 PM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Question Fluids?
Well I'm about to turn 20k on my 03 Touring 6sp. I pretty much set on going w/ the Mobil 1 10w30. I was wondering if anyone has use the Pennzoil Synchromesh for their transmisson? Also anyone change their differential fluid? If so, to what? I know the diff really doesn't need to be change but if I can put something in there to help it out, I will.
Old Nov 25, 2005 | 05:53 PM
I replace all the fluids at the intervals recommended in the maintenance manual. More frequent changes accomplish little. For “type” of fluids, I follow the recommendations in the owners manual. Yes I replaced the differential oil, but I don't recall what brand it was.
Old Nov 25, 2005 | 10:25 PM
Mike Wazowski's Avatar
Mike Wazowski
ROYAL PURPLE, ROYAL PURPLE, ROYAL PURPLE in everything
Old Nov 26, 2005 | 03:40 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
LOL I was looking at Royal Purple last night. The 10w30 motor oil, Max-Gear for the diff. I have a question though, should I use the Max-Gear for the tranny or the Synchromax?
Old Nov 26, 2005 | 08:15 AM
gabez33's Avatar
gabez33
+11111111111111111111111111111111
Old Nov 26, 2005 | 10:23 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
OK but please refer to post #4.
Old Nov 26, 2005 | 02:40 PM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Anyone wish to put their 2 cents in?
Old Nov 28, 2005 | 09:17 AM
Z'd's Avatar
Z'd
for the rear diff:
https://www.amsoil.com/storefront/fgr.aspx
for the 6MT:
http://www.amsoil.com/storefront/mtg.aspx
I changed both at the same time, early on- around 3K miles. The 6MT to make the shifting easier and the rear diff just to get any initial shavings out.
Everything has performed flawlessly over the past 2.5 years.
Old Nov 28, 2005 | 09:42 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Thanks...
Old Dec 20, 2005 | 03:06 PM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
OK... Went with the Royal Purple 10W30 engine oil and Royal Purple Max Gear for the Diff. For the tranny went with the Pennzoil Synchromesh.
Old Jan 8, 2006 | 10:22 AM
dgz32's Avatar
dgz32
The Pennzoil Synchromesh looks to be for very specific applications, though it does say it has "excellent yellow metal compatibility". Still, I'm not sure I'd run the risk, especially with our trannys.
Regarding the Royal Purple, their site mentiones that MaxGear is safe for use in trannys requiring GL-4.
|dg
Old Jan 8, 2006 | 10:38 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
|dg
Thanks... Yeah after further research I'm going to replace the Synchromesh with the OEM oil. I just hope I have'nt ruined anything already. Its only been about 2-3k at most miles.
Old Jan 8, 2006 | 11:06 AM
dgz32's Avatar
dgz32
I doubt that there'd be any harm done.
I *think* I've settled on RP MaxGear 75w90, which is supposedly ok for both GL-4 and GL-5 applications. Still...being that I've replaced my tranny once already...the idea that it works in both applications makes me a bit wary. I do like the idea that I can use it in the differential as well, though.
|dg
Old Jan 8, 2006 | 11:10 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Well all the research I've done and found is that you should use only the Nissan OEM oil. Doubt it really make that much of a difference anyhow. Rather be safe than sorry.
Old Jan 8, 2006 | 03:22 PM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Originally Posted by G35 6MT
So what you're say is to mix 75W80 & 75W90?
Old Jan 8, 2006 | 04:43 PM
350Zteve's Avatar
350Zteve
+1.
Old Jan 8, 2006 | 04:55 PM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Originally Posted by 350Zteve
+1.
OK... But I called Royal Purple and they don't have anything for our tranny. I've already chage the engine oil and rear diff oil to Royal Purple.
Old Jan 9, 2006 | 07:10 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
So where can you get the Shell Spirax and what weight?
Old Jan 9, 2006 | 07:30 AM
MustGoFastR's Avatar
MustGoFastR
What about Redline products?
Old Jan 9, 2006 | 07:49 AM
jakedajewel's Avatar
jakedajewel
If you wish to stay with a Esso product..... yes. ButI won't use a product that suppose to protect yellow metals and then not disclose the copper corrosion test results..... what are they really hiding?
I found the better product is the Shell Spirax synthetic gear oil. I use it in the G35 MT and rear diff. Excellent copper corrsion test result and a true synthetic. Best oil change I've done in awhile. No more crunchies when I speed shift.
Nice write up on gear oils.
