lsd for a base
Old Dec 6, 2005 | 08:39 PM
rory's Avatar
rory
Default lsd for a base
ok so all i need are the vlsd axle stubs and a nismo lsd right. it it will pop right in the base. i searched and searched and got more confused on getting a lsd for a base. but i think iam on the right track i hope.
thanks rory
Old Dec 6, 2005 | 09:39 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
if you buy the NISMO LSD it comes with the axle stubs and everything you need for install..
* you will also need some adjustment shims mostlikely as well *
http://performancenissanparts.com/ca...products_id=59
Old Dec 7, 2005 | 05:57 AM
Gsedan35's Avatar
Gsedan35
thanks rory
Base 350Z open diff + Nismo LSD = No required parts other then what's inside the Nismo LSD box.
Base 350Z open diff + all other clutch type LSD's = Must buy oem LSD stub axles
Base 350Z open diff + swapping in oem viscous c0re to give yourself a VLSD = Must buy oem LSD stub axles. Now also this is the absolute wrong way to get a oem VLSD. By the time your done you will have spend very close to clutch type LSD money and for what. If you have to have a oem VLSD in your car the ONLY way to do it is to buy a used sealed diff that has all the parts already installed. All you do is swap the diff in in your garage and your done,..............for a LOT less $$. Don't make the same mistake I did.
Old Dec 8, 2005 | 08:47 AM
RBlover69's Avatar
RBlover69
where the hell would you buy a VLSD ////used
Old Dec 8, 2005 | 09:01 AM
Jason@Performance
Performance Nissan
junk yards
Old Dec 8, 2005 | 09:32 AM
Vamos_Rafael's Avatar
Vamos_Rafael
how much to get lsd installed?
350Z_Al
Oct 29, 2020 07:44 PM
350z82
Oct 1, 2015 06:25 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
