Nismo VTC Pulley
Old Dec 21, 2005 | 03:25 PM
03_Track_Z's Avatar
03_Track_Z
Default Nismo VTC Pulley
http://www.z1auto.com/prodmore.asp?m...ine&prodid=922
Is this like a less expensive, less powerful of course, alternative to cams? Can someone explain this to me?
Old Dec 21, 2005 | 03:47 PM
bleunetizen's Avatar
bleunetizen
interesting.. wonder if stock ecu will work with it
Old Dec 21, 2005 | 03:54 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
they are for use with high duration cams only
Old Dec 22, 2005 | 01:32 AM
Z350Lover's Avatar
Z350Lover
stock ECU can work with it for sure, but the ECU is not programmed to take advantage of those extra free plays provided by the Nismo VTC unless you alter/rewrite the program or use a stand alone ECU like Motec (only this one is possible to control valve timing at this stage)... if you don't change the ECU program or use a stand alone, those nismo VTC will just work exactly the same as your stock VTC pulleys... They really help with those Spec 1 cams that I am using... I don't lose any torque down low at all with that.
cheers,
richie
Old Dec 22, 2005 | 02:39 PM
meatbag's Avatar
meatbag
Do these allow a greater adjustable range for the cam timing or do they just advance the overal timing?
Old Dec 22, 2005 | 03:01 PM
Z1 Performance
Former Sponsor
there is no way to statically advance cam timing...the sprocket works via oil pressure. The VTC pullies allow for 15 degrees more overall advance, which helps to tame the larger duration intake cams, and make them idle nicely, as well as allow them to 'come on cam' lower into the rev range - essentially it makes an aggressive cam more driveable
Old Dec 22, 2005 | 06:48 PM
G35SD's Avatar
G35SD
Are the Pulleys only installable on the revup egines with CVT on the exhaust cams as well as the intake cams? I have always wondered if and how this part could be installed on the non revup engine.
TIA
Old Dec 22, 2005 | 09:41 PM
Z350Lover's Avatar
Z350Lover
those parts are ONLY for the 03-04 Z... they are not designed for rev up engine at all.
cheers,
richie
Old Dec 22, 2005 | 10:16 PM
XBS's Avatar
XBS
Veteran
How would these do with JWT cams on a forced induction car ( 500 whp ) Any power gains or just smoother idle?
Old Dec 23, 2005 | 04:58 AM
Z1 Performance
Former Sponsor
they are onyl for an aggressive cam as stated...the JWT are no where near enough of a cam to warrant these. Thing Tomei 268, NISMO S1, S2, and maybe Esprit
Old Dec 23, 2005 | 05:52 AM
BlackTuner's Avatar
BlackTuner
In theory they should allow you to have larger cams without the sacrifice of driveability. The upcoming VTC control with items like the UTEC it should allow the car to idle a lot better and find the lost low end torque with large cams.
I have some Tomei cams coming in fairly soon, it will be interesting to see what is found.
Jermaine~
Fixxxercask
Nov 9, 2015 11:10 AM
nanotech
Oct 2, 2015 05:02 AM
Ganglio
Europe
Sep 26, 2015 07:06 PM
