anybody installed their own clutch/flywheel?
Old Dec 22, 2005 | 05:46 PM
tig488's Avatar
tig488
Default anybody installed their own clutch/flywheel?
simple, difficult, timeframe, possible on jackstands?
Old Dec 23, 2005 | 04:27 AM
Lawn Dart's Avatar
Lawn Dart
With the right tools and some mechanical ability, on a scale from 1 to 10, its a 7. First time, it should take you about ten or more hours, and yes its possible on jackstands.
Old Dec 23, 2005 | 06:26 AM
SpeedRcr's Avatar
SpeedRcr
i wouldnt want to do that...i did it on a lift and it still wasnt fun...
Old Dec 23, 2005 | 12:03 PM
overZealous1's Avatar
overZealous1
first time i did it the motor was out of the car. now i get to do it with the engine in the car in about a week. i have done it many times on other cars. it is fun on jack stands when you drop the tranny on your chest and try to crawl back from under the car with it, lol. auto's suck!!
Old Dec 23, 2005 | 02:28 PM
tig488's Avatar
tig488
ill be doing it with jackstands that lift the car about 3 feet off the ground, they are made for heavy equipments, i used them to install my turbo kit. its nice to be able to sit on a creeper and roll under the car. do i need any special tools?
Old Dec 23, 2005 | 05:29 PM
johnlotusboy's Avatar
johnlotusboy
You need a T-55 Torx for the flywheel bolts and disc alignment tool (given), if you have done other clutches not to bad a job. lots of room for access in fact its easy compared to most sticks. Trans weights 147lbs. It is two big dudes needed, maybe, but two normal guys can balance it on a jack and not get hurt..
Old Dec 24, 2005 | 11:00 AM
esfand's Avatar
esfand
i did it on jack stands and it was a *****. the hardest part is lifting the trans and aligning it with the engine. and make sure the T-55 torx is good quality caz cheap **** WILL break and **** u off.
Old Dec 24, 2005 | 12:45 PM
tig488's Avatar
tig488
you think its worth 400 to get it installed?
Old Dec 24, 2005 | 03:16 PM
plumpzz's Avatar
plumpzz
Na its not bad. I've done it on a supra and its not bad if you have a friend and jack stands and a coaster. Its heavy though so be careful.
Old Dec 25, 2005 | 01:42 PM
esfand's Avatar
esfand
yeah 400 is not bad, but doing it urself is a great learning experience. just dont let the trans fall on ur head... it might hurt a lil
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
